Yamaha HS8 Studio Monitor Review
Rate this studio monitor:
    Votes: 8 3.7%
    Votes: 124 56.9%
    Votes: 83 38.1%
    Votes: 3 1.4%
This is a review, detailed measurements, listening tests and EQ of Yamaha HS8. It was kindly drop shipped to me by a member and costs US $800 for a pair.
The silver version I have looks nice and feels nice. There is a shallow waveguide so directivity should not be too bad. And the cut out in woofer ring allows the center of the two drivers to be closer together (to improve vertical directivity).
Back side is rather simple but not sure you need more:
This older audiophile still has a warm spot for classic AB amplification as indicated by the heatsink. :) Testing was performed with all the controls as you see.
I was pleasantly surprised that unlike the NS series, company measurements show rather flat response:
Yamaha professional HS8 Monitor Powered Active Speaker company measurement.png
Let's put it on our Klippel Near-field scanner and see how it does.
Yamaha HS8 Speaker Measurements
As usual, we start with our spinorama frequency response and directivity measuerments:
Yamaha professional HS8 Monitor Powered Active Speaker anechoic frequency response directivity...png
Our higher resolution on-axis response shows digs out more variations/resonances than the company but generally correlates well. There is messiness that is kept rather low between 300 Hz and nearly 1 KHz. We can see some of the reasoning in the near-field driver tests:
Yamaha professional HS8 Monitor Powered Active Speaker driver frequency response measurement.png
The woofer also has some resonances that are not quite filtered out, causing some boost in our on-axis response. The tweeter also has a resonance which is reflected in our anechoic measurements.
Lack of full directivity control causes uneven response in early window reflections:
Yamaha professional HS8 Monitor Powered Active Speaker early window frequency response measure...png
And the same in predicted in-room response (assuming far field listening):
Yamaha professional HS8 Monitor Powered Active Speaker predicted in-room frequency response di...png
This is complex level of colorations which is harder to diagnose and correct. But we will try in the listening test section.
As noted, directivity is not great and we can see that in our plots:
Yamaha professional HS8 Monitor Powered Active Speaker horizontal beam width measurement.png
Yamaha professional HS8 Monitor Powered Active Speaker horizontal directivity measurement.png
The wider response is beneficial however. Vertical directivity is rough as it tends to be in non-coaxial designs:
Yamaha professional HS8 Monitor Powered Active Speaker vertical directivity measurement.png
More the reason to absorb them.
Distortion is good at 86 dBSPL but becomes unacceptable at 96:
Yamaha professional HS8 Monitor Powered Active Speaker THD percentage distortion measurement.png
Yamaha professional HS8 Monitor Powered Active Speaker THD distortion measurement.png
I sort of expect the bass distortion but we have a lot of stuff going on from 200 to 500 Hz. Let's look at what comes out of the port in that regard:
Yamaha professional HS8 Monitor Powered Active Speaker Port distortion measurement.png
Yup. Same thing. Some absorption would have been good. There are also resonant peaks.
Focusing on low frequency, we again see the same issue near 300 Hz:
Yamaha professional HS8 Monitor Powered Active Speaker Low frequency crossover distortion meas...png
During the sweep, I could hear the onset of distortion in lower frequencies even with my hearing protection on. At 101, it was massively distorting so don't even think of running it full range there. Use of a sub with 80 Hz high pass should remedy some of that but not the hump at 300 Hz.
Waterfall display shows lasting resonances:
Yamaha professional HS8 Monitor Powered Active Speaker waterfall measurement.png
Step response looks smooth:
Yamaha professional HS8 Monitor Powered Active Speaker step response measurement.png
Yamaha HS8 Listening Tests and Equalization
I tested the monitor in my usual setup. First impression was reasonable bass extension but depending on the track, response seemed distorted and muddy in bass. It disappeared in techno tracks but would frequently come back during bass that accompanied other types of music. I felt the cabinet and it was strongly resonating on top, left and right. This would in turn excite the shelving I had (despite an absorber between them) resulting in some unwanted noise. But this was not all of it. When I applied EQ to 300 Hz to 1 kHz, this seemed to subside:
Yamaha professional HS8 Monitor Powered Active Speaker equalization measurement.png
But the tonality was not quite right. So I messed and messed with the response based on measurements to what you see above. Now the overall clarity was improved and less emphasis in highs. Correcting for small variations is very hard by ear and eye so more precise work may result in better results.
Yamaha's NS series had so jaded my opinion of the brand that I thought the HS8 would be a horror show. It was not. It is a reasonable effort to produce a brand name monitor at a reasonable price. Design flaws do exist however at small to medium levels in different areas. Equalization did clean up some of it resulting in a good sound with rather deep extension for a monitor of its size.
I can barely recommend the Yamaha HS8 without EQ. With EQ, it becomes good enough.
Happy to see your ears are back as part of the testing protocols !
Well the distortion sure as hell explains why I found these to be incredibly harsh. Wow.
I've heard these once driven by a Yamaha Montage keyboard and thought they sounded great under those conditions. I do mean great! Playing it sounded so much nicer than any other keyboard/speaker combo I've played/heard. I'm not saying these are the greatest speaker ever made, but they aren't bad particularly for their purpose. I don't think anyone who owns a set of these and they are using them in a manner they were designed for needs to run out and buy something else. These are good. Hard to imagine this company makes competent acoustic guitars, acoustic pianos, keyboards, organs, home theater equipment and motorcycles (I'm probably missing a few divisions in there) and they do it all well.
Here is my take on the EQ.
Please report your findings, positive or negative!
For the score rational your journey starts here
Explanation for the sub score
The following EQs are “anechoic” EQs to get the speaker right before room integration.
If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there.
The raw data with corrected ER and PIR:
Score no EQ: 5.7
With Sub: 7.4
Spinorama with no EQ:
  • Somme resonances
  • Resonable performance
  • Directivity could be better
  • Limited output but suitable for nearfield?
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/15deg and have the axis crossing in front of the listening location, might help dosing the upper range. Explanation here.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable (here).
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
  • One can model the EQ with Vituixcad by using the DSP "Generic" setting with 96000Hz sampling rate.
Score no EQ: 5.7
With Sub: 7.4
Score EQ LW: 6.1
with sub: 7.8
Score EQ Score: 6.6
with sub: 8.3
Code:
Yamaha HS8 APO LW EQ 96000Hz
April262026-145817
Preamp: 0.00 dB
Filter 1: ON PK Fc 94.5 Hz Gain -1.38 dB Q 1.77
Filter 2: ON PK Fc 437.8 Hz Gain -2.01 dB Q 2.16
Filter 3: ON PK Fc 759.4 Hz Gain -1.96 dB Q 3.23
Filter 4: ON PK Fc 1233.0 Hz Gain -1.58 dB Q 6.00
Filter 5: ON PK Fc 1336.0 Hz Gain 1.18 dB Q 0.94
Filter 6: ON PK Fc 2643.1 Hz Gain -1.90 dB Q 1.00
Filter 7: ON PK Fc 11945.3 Hz Gain -1.20 dB Q 3.27
Yamaha HS8 APO Score EQ 96000Hz
April262026-145817
Preamp: 0.00 dB
Filter 1: ON PK Fc 105.2 Hz Gain -1.31 dB Q 1.71
Filter 2: ON PK Fc 437.3 Hz Gain -2.27 dB Q 1.97
Filter 3: ON PK Fc 756.2 Hz Gain -1.79 dB Q 2.56
Filter 4: ON PK Fc 1229.8 Hz Gain -1.62 dB Q 5.89
Filter 5: ON PK Fc 1340.4 Hz Gain 1.42 dB Q 1.08
Filter 6: ON PK Fc 3016.5 Hz Gain -2.64 dB Q 0.53
Filter 7: ON PK Fc 11645.9 Hz Gain -1.95 dB Q 1.50
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
No improvements?
Bonus Amirm EQ:
Score Amirm EQ: 6.1
With Sub: 7.8
Score no EQ: 5.7
With Sub: 7.4
Score EQ LW: 6.1
with sub: 7.8
Score EQ Score: 6.6
with sub: 8.3
The rest of the plots is attached.
  • Yamaha HS8 APO Score EQ 96000Hz.txt
  • Yamaha HS8 APO LW EQ 96000Hz.txt
This is an interesting review. I have two pairs of these monitors. I use one pair with my computer and audio-related devices (Grace Design m108, MOTU 10pre). I make voice recordings (spoken word)--no music. The other pair is connected to a digital piano (Yamaha P525; it is merely incidental that the monitors and piano are both of the Yamaha brand).
I have the subwoofer that goes with this series, an HS8S. It is in storage. I do not really have space for it, though perhaps it might be of use with the piano (?).
Could it be reasonable to suppose that for pair I use for spoken word recordings, the shortcomings mentioned in this review would not be consequential? And for the pair connected with the piano, is that a use where the HS8's shortcomings could be relevant?
My questions aside, I wish to mention that my academic background is not in engineering.
  • Yamaha HS7 Measurements Professional Monitor frequency response spinorama CTA-2034.png
  • Yamaha HS5 Studio Monitor Powered Speaker CEA 2034 Spinorama Audio Measurements.png
Depends a bit on the use case ”resonances and not quite right tonality” ? if you happily can play our piano that’s seems ok it could possibly sound better if you changed speakers. Is this only for your own entertainment ? Do you adjust tonality of the instrument ? Or record your playing and publish it somewhere.
Do you publish your spoken word work ? Do you in any way adjust tonality of the recording ? With EQ or fiddling with your mixer and microphone ? Using speaker in thier monitor role is bit different than enjoying music out of them , now your are supposed to judge if something sounds right by these speakers when you produce your recording ?
Listen to your stuff on some other systems ( second opinion basically) is it acceptable there ? Maybe your audio work does not demand that level of precision.
The HS series starts showing its age, although I expected it to measure worse being the largest model of the series, the loud highs due to the directivity mismatch above 2 kHz can be partially corrected also with the integrated shelving filter:
Always wondered this with actives...but with all that "junk" randomly behind the woofer surely sound waves are broken up and reflected every which way ( good?) and the amplifier components must resonate like mad - it must all have an impact on sound?
I put some LBM's actives together a while ago and the designer of those has gone , in my mind, a long way to removing that concern. If all this "junk" does matter then why go to the lengths people do with the cabinet design on some (not this one) of these active designs?
I also just made some Seas Mimir passive DIY speakers and put all the crossover "junk" in a separate sealed box below the main speaker cabinet - just because it inherently feels better to me. Probably a waste of time but there you go..
Thank you for your reply.
For the piano, nothing is ever changed in terms of tonality. The instrument is played in the home (by someone else; I don't know how to play), and nothing is recorded or published. At some point, the piano might be connected with a computer and digital audio workstation application for use with music notation software. If you (or others, perhaps musicians?) happen to have any suggestions on what monitors might be more suitable for the piano, I'd welcome them.
For my spoken word recordings, they are used in an academic setting (inlcuding online courses). The recordings are merely lecture-type notes, verbal instructions, and so forth. The signal from the microphone (usually a Shure SM7dB) runs through a channel strip (Grace Design m103). I'll insert the graphic of the equipment rack so that you can see the EQ settings on the m103. The effects of the EQ are moderate (notwithstanding a couple +12dB settings), and the compressor on the m103 is bypassed. The signal from the m103 goes to Ch. 2 of an Aphex Model 622 Expander/Gate. The Aphex unit is used to "gate out" ambient noise (e.g., air conditioning noise, planes flying overhead, outdoor traffic, and so forth). The ambient noise is never extreme. It is usually only the air conditioning sound that I wish to prevent in my recordings. From the Aphex, the signal goes to a Grace Design m108 microphone preamplifer/ADC.
Before using the Grace Design m103, I was using a dbx 286s channel strip, and the EQ settings there made dramatic (and to me unnatural/"exagerrated") differences in my voice. I got the m103 after the dbx unit stopped working properly (e.g., intermittent static noise, an almost complete loss of signal).
In terms of whether my voice recordings sound "right", I would say that they do. Put another way, I recognize myself in the recordings and don't sense that the sound of my voice is changed unnaturally. Students tell me that my voice sounds as it does "live" (students in my face-to-face courses listen to my voice recordings for some of their coursework). At times, instead of typing emails to friends, I send voice recordings. They say that I "sound the same".
Curiosity has led me to listen to my recordings on other devices, including mobile devices (tablets, laptop computers, mobile telephones), desktop computers with whatever speakers are connected to them, and even on my music playback equipment. The sound seems all right, with nothing obvoiusly amiss. When I make my recordings, I use headphones (Sennheiser HD 300 PROtect).
I will mention that listening to music on the Yamaha HS8 monitors is definitely different from listening on my music playback system, and I attribute that to the fact that they're small monitors (not floor-standing loudspeakers), they're in a different room than where my sound system is, and they're off to the side (my listening space at the computer is not an equilateral triangle). The rare music listening I do with the Yahamas is always at a low volume. When I want to listen to music, I use my Hi-fi stuff.
Below is an excerpt from the m103 manual on the EQ:
The m103 equalizer section has 3 bands, with a fully parametric mid section and sweepable low and high sections. This equalizer has been crafted to be very powerful and versatile with no compromise to the transparency and detail of the signal. Because of its high level of precision and accuracy, you may find yourself being able to hear a much smaller amount of cut or boost than you would with other EQ designs.
Both the low and high sections can be operated in either peak -0- or shelf > mode. Peak mode, as indicated by the bell shaped icon, is used to cut or boost a specific frequency. Shelf mode, as indicated by the shelf icon, boosts or cuts all of the frequencies above (for the HI band) or below (for the LOW band) the frequency selected.
glad to see them eventually measured. previously had krk rokits 8 and i happily swapped them for hs8 with the feeling of relief. they stayed with me until had to change for something smaller/active. distortion was never an issue for me, i'm surprised they are that bad in thd!
These are the classical 500 euro recommendation in Europe when it comes to desktop nearfields for set and forget.
There was a time at the distant past they had reliability problems at their 5 year mark but this has been addressed for many years, plus it was easy to repair (yep, bad batch caps)
Nice to see they measure somehow decent, I was expecting worst as at their default setting and not good conditions can be brighter than the sun.
Thanks Amir!
This might have been a great pair of monitors 20 years ago, but nowadays it is just not competitive. Thanks for testing though, it is still a VERY popular model AFAIK.
