Yamaha CR-1020 Vintage Receiver Measurements and Features
MAB
Portland, OR, USA
A good friend of mine got a Yamaha CR-1020 receiver at a local sale. It is in great cosmetic shape. I'm going to test it.
It was bought along with a more powerful CR-2040 which unfortunately was recapped, and the two 22mF filter capacitors were replaced with larger parts that couldn't be secured with the existing strain relief. The well thought out metal bracket was bent aside, cardboard was lightly stuffed, prayers were likely quietly uttered for good luck.:facepalm: At some point the weight of unsecured upgraded capacitors cracked the power supply board near on of the standoffs.
I will fix that at some point.
Fortunately the CR-1020 is unmolested. I cleaned it, fixed a couple issues, adjusted the bias. Here are the performance results, and tests of a few of the features.
This Yamaha Receiver was released in 1977. The serial number is missing, so I am not clear on the exact date of manufacture, but likely 1977-1979. When introduced, it was Yamaha's second most powerful and feature-laden receiver.
It has inputs for two turntables (MM only), two tape decks each with tape loop, auxiliary, plus the built-in AM/FM tuner. It has three-band tone controls plus Yamaha's variable loudness. :DAdditional features include low- and high-cut filters, and two headphone jacks. It is wide (21.25", 540mm) and heavy (40 pounds, 19 kilos). The next unit above this in Yamaha's 1977 lineup was the CR-2020, which had 100 Watts per channel with similar features.
Preamp out / Main in allows testing of each component independently, and make this unit particularly future-proof.:cool: You could add DSP or integrate subs.:) Lots of switchable speaker connections, and electrical outlets for additional equipment.
With so much stuffed into one chassis, there must be compromises.
Also, is the urban legend true that Yamaha electronics have a lean and bright sound? Alternately, should we go break the bank on vintage electronics and receivers?
I will try to answer some of these questions.
First, let's look at the preamp:
Here is the THD and Noise with 2.5V input signal, and the volume control gain adjusted to just under 2V output. Note that I needed to adjust L/R balance, more on that in a bit.
This is respectable performance, neck and neck with my Apt Holman preamp, or a Parasound JC2 (which I don't have).
Sweeping the input voltage gives the following noise and distortion vs. output:
Good performance across a fairly usable range. Spec claims 0.02% THD at 1kHz, with maximum output of 5 V, which it does.
As noted, the volume control has a Left / Right offset. The top graph is Left and Right vs. overall gain. The bottom is L-R for three different runs, one while increasing the volume, another while decreasing the volume, and a third with the -20dB mute switch depressed (offset by 20dB for the overlay).
Up vs. down was to see if there is some asymmetry in the wiper, there is not. The -20dB offset is just to see if it is exactly 20dB (it is), and if it has an effect on the balance (it does not). My experience with receivers is volume controls are often mismatched L and R even when new, no idea if this is age or tolerance. I measured the resistance, it is L/R mismatched, and no amount of cleaning addressed the issue. The mismatch is 2dB at unity gain, fairly high volume, but certainly in a region where the unit likely will get used and the imbalance will be potentially audible. This is probably one of the biggest issues with the unit, possibly has been there since day 1.
The tone controls are vast. Here are the bass and treble contours for each detent:
Not as useful as PEQ, but fun! And they match the frequencies that Yamaha published in their literature.
Yamaha has a great variable loudness feature on many of their older integrated amps and receivers. The control has 11 detents, Flat to 10. Rotating the knob reduces the volume in approximately 1dB increments, each reduction increased the depth of the Fletcher-Munson Compensation curve. Below is the measured performance of the control at the bottom, with the family of equal loudness curves above:
I aligned the frequency scales, but the Y-axes are not scaled. Yamaha's circuit isn't exact match to the loudness compensation, but is really useful. It's a great way to reduce volume up to ~10dB, retaining the similar perceived tonal balance.
Regarding the long repeated urban legend of Yamaha having a lean sound, here is the frequency response of the preamp, including the performance of the high and low filters:
This receiver is -1dB at 10 Hz and 70 kHz, and +- 0.2dB from 20Hz to 20kHz. Not lean or bright. Nor are the contemporary gear from other manufactures attenuated in a way that might make a flat-measuring Yamaha sound bright in comparison. It's fairly contemporary performance. The High and Low cut filters are exactly 12dB/oct at the corner frequencies Yamaha specs in their literature.
I measured the phono preamplifier. It has two selectable inputs, both use the same Moving Magnet preamp.
Here is the performance with a 5mV input signal:
36dB gain, and it meets Yamahas spec for THD and SNR. It's quite good performance.
If I sweep the input voltage, it clips at 250mV:
Frequency response to the RIAA EQ curve is near perfect, 0.5dB bass boost that definitely isn't lean, if it is audible.:cool:
This is a good phono stage.
After cleaning and and repair of the Pre-out/Main-In switch, the unit operates flawlessly, buttery smooth. The controls are a joy to operate. The FM tuner pulls in my usual stations. The meters provide useful info. It all looks cool and brings back good memories.
The power amp is specified by Yamaha at 70 Watts per channel, 0.05% THD. I did have to adjust the bias on both channels, which had both drifted low by an equivalent amount. After warm up, both snapped to spec with a slight turn, and stabilized with no fuss. Neither has drifted in the few weeks I have had this.
I tested the amp using the Main in RCA jack.
At 5 Watts, it performs great, with noise and distortion as good as many contemporary amps.
Here is the left channel swept into 8 and 4 Ohm loads:
This exceeds spec into both 4 and 8 Ohms!:) Driving both channels reduces peak power by about 5 Watts, it still has margin to Yamaha's published numbers. It got hot during power testing, but not unduly so. The frequency response of the amp is flat to from 5Hz to 10kHz, down 0.5dB at 20kHz.
What a great piece of vintage gear. I'm a fan of Yamaha, and stem to stern this doesn't disappoint. Aside from great looks, it has really good performance, with the possible exception of the volume control. And no hint of lean, clinical sound.;) All in one very wide and heavy package. I seldom see one of these big beasts tested, I hope you find this interesting.
Neat-o! Thank you for sharing this information.
FWIW, I've always enjoyed the sound of that era of Yamaha equipment. It's never struck me as lean or clinical sounding. These components paired exceptionally well with popular (and popularly priced!) loudspeakers of their day, too -- e.g., the Polk "Monitor Series" loudspeakers of the same era.
PS The CR-1020 that lives here says hi and thanks for the write up!
PPS So does the CR-2020 (not wanting to be left out). ;)
The CR-1020 and its siblings are also -- realizing full-well that this is subjective and untestable -- beautiful.
It is hard to believe that the same aesthetic Zeitgeist that produced the leisure suit also spawned this era of Yamaha audio components. ;)
Thank you MAB! I still after 20 years regret throwing away my CR-820... The volume pot was in need of cleaning, otherwise it was perfect after 20 years of service. I have used black Yamaha RX-V... AVR's since
Isn't it wonderful that a unit nearly fifty years old still beats spec and generally performs well?
I don't mean to throw a wet blanket on things, but my favourite, still available (just) in the UK in 1977, was the original CR1000. Ooh, I LOVED that one, with it's slightly creamy tones and so-slick sliders. For some reason, the tab switch controls went thicker and clunkier (in comparison) in the **10 and **20 models over the previous 400/600/800 models.
Antway, this CR1020 is from an age we'll arguably never see again and as it's part of my early years in the industry (we sold a lot of Yamaha back then), it's sad that it's so long ago and long gone...
Stunning looking piece and good measurements,
Makes you wonder what the so called "high end" brands really have been doing the last 40-50 years right?
anyways i just bought an Yamaha AX -1070, 2nd hand but from a shop and with guarantee, thing weighs 18,3 Kg and is built like a tank
It has almost all the same controls inc. the variable loudness
I was planning to use it purely as power-amp (amps are devide-able) because i have a pretty good pre-amp already, but we'll see.
Marvelous and interesting review. Thank you.
I'd love to see how it performs on recovery from impulse!
Reactions: MAB
Wow, just wow,
Are you or were you a Yamaha dealer or is this just hobby?, i'm slightly jealous;)
Thanks for the test MAB.
The Yamaha CR-1020 was a beautiful vintage receiver. Good performance to. One in good condition with some speakers that are at least 88 dB sensitive would be great. :)
(or lower sensitivity speakers if you usually play at a relatively low volume, let's say around 65-75 dB)
I had a quick look at Hifishark. Sold in Europe around $550. In the US I don't know. In any case, one in good condition will most likely not drop in price, but rather increase. Unlike some new small (even good ones) class D amplifiers. There the price trend is the opposite.
Buying a receiver that is approaching fifty years old without having the knowledge and ability to fix electronics, maintain, service and repair, well ....that's another question.
When/if necessary, there is, however, the option of leaving it to a professional repairman , who charges per hour.
What an excellent, in-depth review of an audio device that is not only timelessly beautiful but also a masterpiece of no-nonsense engineering and functionality—making it a tough act to follow for most similar equipment that came afterward.
Buying a receiver that is approaching fifty years old without having the knowledge and ability to fix electronics, well ....that's another question.
Well my Dad's 1979 CR 240 is still going strong and of the amps I've owned it performs with among the best, especially when one considers all of the features it has. Most disappointing Emotiva BassX A100.
Angus McKenzie (a known fully-tech reviewer of the times) tested the CR1020 in a mid 70s 'Receivers' issue of HiFi Choice (worldradiohistory in the HiFi Choice issue pages). It didn't actually come out that well for (radio performance it seems) reasons clearly published, although he was a bit crabby and a 'nitpicker par excellence' as I remember both in print and personally, as my then manager related to us. The Sansui 9090 was *the* favourite model back then I recall.
https://www.worldradiohistory.com/UK/Hi-Fi-Choice/1975-1982/Hi-Fi Choice Iss. 007 Receivers.pdf PDF page 152
Wow, just wow,
Nope, just a collector :)
Long story short: When I caught the "stereo bug" (ca. 1976) I was very short on funds, so I window-shopped a lot. Listened to many different things (many, though not all, dealers were surprisingly tolerant in those days of scruffy but earnest college students). I bought a Yamaha CA-610II in 1978 (which, unsurprisingly is still here and still works well and sounds good to me).
Much, much later, after our own kids were grown & more or less on their own, I got interested again. One of those interests was along that line of "recapturing lost youth". I couldn't afford the better Yamaha stuff then, but -- informed by the notion which I like to call "Pasteur's Dictum"* -- I could "now". :)
The aforementioned CA-610II, when it was more or less new :)
... and in a more recent (but hardly current) photo:
____________
* i.e., "Chance favors the prepared mind", as it's often rendered in English.
Thanks for finding this!
Wow, I'm exhausted just thinking about him testing all of those receivers. :cool:
Yes, he is quite critical of the tuner's performance. It was of high importance back then, valid criticism if a receiver's radio didn't perform well.
I have one of these. I made a mistake and fried the amp section. The shop I took it to was unable to source the needed part. Now it feeds LS50w as a phono preamp,an FM source and a source for a chrome cast audio. FM is only “ok” but I probably need a good antenna. In any case the only station I listen to is a public radio music station. Hope they survive.
