Yamaha CD-S303 Review (CD Player)
NTTY
Reviewer
Switzerland
Hello everyone,
This is a review and measurements of the Yamaha CD-S303 CD player and transport:
This is the latest iteration of Yamaha entry level CD Player. As you see can from the front face, no phones out but a USB input which will accept MP3, WMA, LPCM and FLAC files.
I think the look is nice and the shape of the buttons reminds me off good old vintage Yamaha devices.
The back show the essentials:
We get RCA analog output and tow digital SPDIF digital outputs.
This Yamaha uses a basic BurrBrown DAC, the PCM1780 which integrates a selectable digital filter. Measurements will show that Yamaha went for the sharp filter (nice) but the performances are on the low side, with a stop band attenuation of -50dB from 0.546fs, as per BB's datasheet, which is exactly what I measured (see later in this post).
THD+N at 48kHz is said to be 0.002% (-94dB) at best, @0dBFS with 24bits data (no 16bits data provided). I suspect this is THD dominated, and so we'll verify that from CD Audio.
Yamaha published the below main specs:
  • Output Level (1 kHz, 0 dB, Fs 44.1 kHz): 2.0 ± 0.3 V
  • S/N Ratio (IHF-A Network) (1 kHz, 0 dB, Fs 44.1 kHz): 105 dB or higher
  • Dynamic Range (1 kHz, 0 dB, Fs 44.1 kHz): 96 dB or higher
  • Harmonic Distortion (1 kHz, 0 dB, Fs 44.1 kHz): 0.003% or lower
  • Frequency Response Audio CD: 2 Hz – 20 kHz
We'll check the above ;)
Some additional comments:
  • This Yamaha features a "pure direct" mode that deactivates digital output and turns off the display. It did not have any impact on my measurements.
  • The USB input is meant to play audio files as you play a CD with possibility to switch from folders. Please check the user manual before you think about using it this way.
  • Before testing, I ensured that the latest available firmware (V1.63) was installed.
When it comes to end user experience, I can't say I was really pleased. The mech is relatively slow, but similar to other recent products (such as the Denon DCD-900NE), so it's decent but really far from a good old CD Player. The buttons don't have a luxury touch and are sometimes unreactive. Reading the TOC of a 40+ tracks CD takes around 8 secondes. But, as a friend told me, none of these are real issues when you use a CD Player to play a full album at once. Fair enough.
It will go to sleep alone after some time (cool), but it’s impossible to wake it up from any of the buttons on the front face. We have to use the remote or the power button (power off and on again).
Yamaha CD-S303 - Measurements (RCA outputs)
All measurements performed with an E1DA Cosmos ADCiso (grade O), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the Onkyo C-733 review. Over time, this will help comparing the devices I reviewed.
The Yamaha outputs a low 1.74Vrms, that is 1.2dB less than the standard 2Vrms. It means when directly compared to another player, it might not shine unless you increase the gain by the same 1.2dB with your preamplifier. Note this is in line with the published specs of Yamaha (2V ±0.3 V).
The tow channels matched at 0.06dB, which is very good. The unbalanced outputs respect absolute polarity. Phase is dead flat.
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (RCA out):
The two channels are shown but only one gets represented in the dashboard (the best one). The THD+N is limited by the noise, but better than the published specs from Yamaha (0.0022% vs 0.003%).
There is indeed a higher than best in class noise floor (which is limited to CD Audio on this test, since no dither is used), but let's see if it improves at lower level.
And so, let's have a look at -6dBFS as I'm used to show:
It repeats again. You can visually see this higher noise floor, for instance if you compare with the ancient Sony CDP-597. Nearly 3dB are lost in low level random noise, of an unknown origin to me.
Distorsion is low, though.
Besides this higher than usual random noise, we don’t suffer power supply leakage:
We can't see below -130dBr because of the random noise, but that is anyways very good on that perspective.
Next is the bandwidth:
You can see the limited channel imbalance. This is flat (-0.1dB only) but you can see the beginning of the digital filter ringing at the end of the bandwidth, due to its poor performances.
Let's have a look at it with a wider bandwidth:
As per specs, -50dB attenuation at around 24kHz, with typical ringing past that, as we had in the early 80s'. If that has a sound, then you get it.
We can also see the noise shaping effect of the delta-sigma conversion with an increase of the noise floor beyond 25kHz.
If you compare with the Sony CDP-597, you'll see a significant difference in favor of the Sony...
My guess is that the low performance of this digital filter is what partially explains the higher noise floor in the audio band of the Yamaha, but I don't think it's the only reason.
Let's have a look at the multitone test that a lot of you like very much:
Again, besides elevated noise floor, this is a good trace.
Let's move on to the jitter test:
Red trace is the analysis from the digital outpuT of the Yamaha, and the blue one is from RCA outs.
And again, we get a higher than usual noise floor, but the trace is good with minimum artifacts.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-X333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
Sony CDP-597-30.4dB-24.7dB-16.5dB
Yamaha CD-S303-65.8dB (noise dominated)-37.1dB-20.6dB
The results of the Yamaha mean that the oversampling filter has a headroom of more than 1dB, which is to appreciate. It's not much but it's better than many others.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
And one more time we suffer from the low level noise which partially masks our 3DC view.
In addition, without dither, and as we can see by the lack of perfect symmetry on this view, there is a deviation of linearity by 0.8dB, which is a surprise (to me) for a modern DAC.
Other measurements (not shown):
  • IMD AES-17 DFD "Analog" (18kHz & 20kHz 1:1) : -90.1dB
  • IMD AES-17 DFD "Digital" (17'987Hz & 19'997Hz 1:1) : -75.5dB
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -89.9dB
  • IMD DIN (250Hz & 8kHz 4:1) : -85.1dB
  • IMD CCIF (19kHz & 20kHz 1:1) : -74.9dB
  • IMD SMPTE (60Hz & 7kHz 1:4) : -86.6B
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -112.5dB
  • IMD TDFD (13'58Hz & 19841Hz 1:1) : -97.1dB
  • Dynamic Range : 95.7dB (without dither @-60dBFS)
  • Crosstalk: -131dBr (100Hz), -129dBr (1khz), -104dBr (10kHz)
  • Pitch Error : 19'996.74Hz (19'997Hz requested) ie 63ppm
  • Gapless playback : Yes
The IMD scores are good, the DR does not reach the published 96dB, again because of that low random noise.
The clock deviates more than what I'm used to see for a modern CD player. And even if that 63ppm is not much of a concern for audio, it is hundred times higher than the Denon DCD-900NE...
Last and not least, I like to run a THD vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I overlaid the result with the much older Sony CDP-597 that I previously reviewed:
It is not bad for the Yamaha, when looking at THD only, but does not reach the good results of the early 1bit (economic) DACs of Sony.
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
OPPO BDP-9518.7bits100%
SMSL PL-20018.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Denon DCD-SA118.5bits98.93%
Denon DCD-900NE18.5bits98.93%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.84%
Accuphase DP-7016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
One more time, it is the low random noise of the Yamaha that limits the performance. It prevents it from reaching my defined threshold of 17bits for this test, which is sad for a modern device.
Yamaha CD-S303 - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
The Yamaha took 8 seconds to read the TOC of my 40 tracks test CD (this is a bit slow).
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)up to 1.25mm
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmup to 1mm
Successive dropoutsFrom 2x0.1mm to 2x3mmup to 1mm
The Yamaha was able to read without generating typical digital noise with dropouts up to 1.25mm. I could measure interpolation starting at 1mm but I could not hear it. Beyond 1.25mm dropouts, the Yamaha failed to play the tracks. This is below what I measure with modern drives (usually having no issue to go beyond 2mm). It is the typical performance of ancient Sony KSS laser heads, but these were mega-fast.
Yamaha CD-S303 - Measurements (Digital Optical Out)
I've seen several of you reviewing CD players using their digital outputs, in case the results could be improved from an external DAC.
So let's go with the 999.91Hz @0dBFS:
No issue here, as well as with the 3DC view (997Hz @-90.31dBFBS):
But I think that from now on, I will just use the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB and so if the signal would be modified before being sent, it would show either a reduction of amplitude or we'd see some sort of saturation/increase noise/distorsion. So here we go, the below is a comparison between the WAV File directly processed by the PC, and when played by the Yamaha via the optical out:
The traces are identical. The Yamaha is a "perfect" transport.
Conclusion
As much as I like Yamaha for the great products I own from them, I'm disappointed by this CD player, even if I must admit I could not hear a difference with other ones when listening to my preferred music.
That said, seeing this modern CD player suffering the comparison with much older ones... kind of made me sad. There were indeed too many places where the Yamaha did not deliver per my expectations: low level random noise, clock deviation, less than usual resistance to scratched CDs, early departure from linearity, low performance filtering,...
What I measured comes from the early 80s' in many respects. The CD players of the time were not sounding bad, but if you think they had a sound, then you might want to consider this Yamaha.
It is a good transport though, but note that the clock deviation will transition to your DAC, even if that is negligible. See below (the 0.06Hz difference):
I hope you enjoyed the review!
May I quickly butt in as regards playing damaged or scratched discs?
Does the Yamaha beat the red book specification for error/scratch reading? if so, it's not an issue I feel. In the 90's, there were one or two mechanisms (Philips CD-M9 was golden in this regard) that could track the side of a digital house if they needed to, sometimes with inaudible error correction/interpolation. Other mechs, including the cheap three-beam type Philips/Marantz went over to, were nowhere near as good. This was important then as discs available in the UK weren't always being manufactured to spec, but this seemed to be all but sorted out once the mid-noughties kicked in...
Whatever the performance, this machine does look cool and the SA-CD 1000 model is a fabulous and slick thing to use and seemed to 'sound' great when I used one briefly.
If they marketed it as 'vintage like' it would hit the nail, not? :cool:
Hi,
Per the documentation available to me: 0.2mm without error correction, up to 2.4mm with it (to double check).
The Philips CDM9-Pro in the EMT-982 was able to read with 2.4mm dropouts.
I test with dropouts up to 4mm, and only the Tascam CD-200 managed to succeed up to that level, for the CD Players that I tested.
Thanks for the detailed review. Other than the good looking silver color, this product doesn't have much to offer. Another electronics giant finishing their CD product line with a whimper.
Hello everyone,
All measurements performed with a Cosmos E1AD (grade G) and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
Besides this higher than usual random noise, we can't see power supply leakage:
I go compare with the Sony CDP-597, you'll see a significant difference in favor of the Sony...
My guess is that the low performance of this digital filter is what partially explains a higher noise floor in the audio band of the Yamaha, but I don't think it's the only reason.
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
And one more time we suffer from the low level noise which partially masks our 3DC view. In addition, without dither, and as we can see by the lack of perfect symmetry on this view, there is a deviation of linearity by a little more that 1dB, which is a surprise (to me) for a modern DAC.
As a matter of facts, with or without dither, this CD Player (or its DAC) deviates from linearity (by 1dB or more) as soon as @-80dBFS.
As I did with the Sony CDP-597, introducing a new "max DAD resolution" measurement, I ran the same with the Yamaha and here the results compared to others:
Sony CDP-59717.5bits94%
SMSL PS-200 (from otpical out of a CD player)18.6bits100%
Onkyo C-73318bits96.7%
Yamaha CD-S30316.8bits90.3%
In this test again, it is the low random noise of the Yamaha that limits the performance. That prevents it from reaching my defined threshold of 17bits for this test.
The Yamaha was able to read without generating typical digital noise with dropouts up to 1.25mm. I could measure interpolation starting at 1mm but I could not hear it. Beyond 1.25mm dropouts, the Yamaha failed to play the tracks. This is below what I measure with modern drives, having no issue to go beyond 2mm. It is the typical performance of ancient Sony KSS laser heads, but at least these are mega-fast.
The traces are identical, the Yamaha is a "perfect" transport.
Conclusion
So cool! We need more of this kind of tests of vintage CD or Amp stuff!
The slow death of the reliable CD player has finally moved me almost totally to streaming. Ripped I no longer need to worry if my old players are going to last. When my Oppo finally gives up the ghost I can just stream everything 100%. There are just too many issues with modern players. They don't last, or don't support features like gapless, or have issues with scratched discs. Many are also just flat overpriced, this very mediocre player is US $450. You can buy a good HD Blu-ray player from Panasonic for nearly that price. The other nice thing about ripping is once I'm done I don't have to worry if a player supports HDCD, SACD, Blu-ray or whatever. It all works as intended ripped to a FLAC file.
Yes, indeed!
Thank you for another interesting piece of documentation about CD players.
i like the test of pure direct, i know amp seem to have an effect, but dac does not, thats good to know
Thank you for the interesting review. I have the older version of this, the S300. I paid $164 for it from Amazon in 2010 USD.
I haven't used it in several years. For a while, I enjoyed the tactile experience of handling CDs, reading the covers, etc. But, then I started needing reading glasses and got hooked on the simplicity of playing my the ripped FLAC files from my library or using a streaming service and stopped using it altogether.
It won't win any awards in terms of measurements, but it sounds fine to me.
I have a 20-year-old Cambridge Azur 540C that I use as a transport with a Schitt Modi 3 DAC. I like the combo more than the internal DAC.
Perhaps as a transport, this player can be seen as a moderately priced option at $450. But for the same price, I'd take a gamble on the Cambridge AXC35 instead.
A bit of a pity, since it was on my list in case my Marantz bites the dust. So I'll have to turn to Denon and go without CD-Text.
Thank you Florent for this new review! Results are somewhat disapointing from theorical point of view. I must admit that i can’t hear any difference between the cd s300 and my Sony scd 555es, the latter beeing certainly much more perfect.
The appearance is at least backwards compatible with older Yamaha kit.
£400 in the UK, I thought it might be half that price from looking at the spec and overall build quality.
The prices you all mentioned are way higher than what I paid, but I guess exchange rates recently evolved in favor of the Swiss Franc.
That made me check the price of the Denon DCD-900NE which I see has increased a lot. It is 40% higher than this Yamaha. So they can’t be compared.
The Denon DCD-600NE is of the same price as the Yamaha (for me locally), but I did not test it. That would be an interesting comparison though.
The 900NE is actually cheaper here, £330 - the 600 is £260. Surprising differences.
Can you please let me know more about these measured improvements? Maybe I can look at the same? I don’t recall exactly what I checked but I could document with/without pure direct from couple of measurements.
I’m looking at getting this to use as a transport, good to know it can do that job!
I also own the older version of this, the 300. I purchased it about 10 years ago at the same time I bought the Yamaha A-S801. While the 801 has been a constant joy and work-horse, the CD player just.....ok. The door started sticking and overall quality felt cheap.
