- Joined
- Dec 12, 2019
- Messages
- 18,478
- Likes
- 42,583
yeah, I missed that, too.
No - The Onkyo was reset to factory defaults and is not using any room or eq corrections - it's essentially out of the box with pure direct mode enabled. Has good bass and lively sound. The Yamaha has nothing other than acceptable treble, hollow mids and lacking bass. Adjustments to the bass tone on either filter setting just results in muddy boomy bass from the yamaha which doesn't get anywhere near as low as the Onkyo produces. Speakers are in the same location, nothing is changed other than switching out amplifiers.Just looked in more detail - you are comparing with your Onkyo AVR - did you use the "automatic speaker setup" with the ONKYO.
If so that would explain a significant difference in bass perception - the Yamaha - as far as I can see - doesn't have any sort of room EQ available.
Why, so my digital audio will sound exactly the same? The OP clearly states the complaints are from both sources, TT and DAC. This has nothing to do with where the TT is sitting. This is a 90% digital source setup, in my office running from a PC. There happens to be a turntable in here too.Holy shit.
Didn't even look at the picture. @orangetang, listen to @DSJR, and get the turntable *way* away from the amp.
Certainly sounds like it.Sick amp, needs a doctor
Maybe a simple question... however you don't have the speakers out of phase do you?Issue is, I really don't like how this unit sounds. I find I need to dial the loudness between 5 - 9 and boost the treble to make anything listenable. My vocabulary and definitions for explaining characteristics of sound is poor, but mainly the issue is with overwhelming mids and higher end of the bass frequencies. The sound is possibly a bit shrill and the bass feels very boomy and without precision with no punch at all. There are frequencies in the low-mid end that seem overly powerful that no adjustments to the tone controls can really mitigate without rolling back the bass all the way - which obviously is not an option.
Means … does it sound way better with just a single speaker connected?Maybe a simple question... however you don't have the speakers out of phase do you?
JSmith
100% checked to ensure not the issue, ran individual wires. That said, I haven't actually checked polarity. This is a valid question since the guy that repaired this unit replaced the A speaker block... I should ensure it's pinned out correctlyMaybe a simple question... however you don't have the speakers out of phase do you?
JSmith
Contact the seller again, and again. Don't give up. You just need to say that he sold you something he said worked but doesn't.I have sent a message to him earlier today but not heard back yet. This is a 700 km round trip to drop it off even if we came to an agreement so it's not going to be ideal in any scenario.
Generally speaking, would the monitor outs allow me to record a sample of what I'm hearing, or is the signal out of the line level outs comparatively different than the high level speaker outs if there is an internal issue - or might it specifically depend on where an issue lies?
I've got a multimeter... with some instruction I could test some stuff, but that's all I've got for electronics testing equipment. No scope or otherwise.
