Yamaha C-2 Review (Vintage Preamplifier)
I owned a Yamaha C-50, which appeared a little after this one circa 1981. It performed well, but was a reliability nightmare because of those little orange Matsushita relays in the signal path. I had it paired with an Adcom GFA-535 -- but not for long. :(
C-50, C-60, C-80. All terrible. Did I miss any?
C-70, C-45, C-85
Props for consistency, right? :rolleyes:
I'm still using two Yamaha units from later on in the '80s that are doing yeoman service four decades later, so apparently the Yamaha folks eventually pulled their reliability act together, at least to some extent.
On the other hand, one of the better audio techs on U-Toob was stymied by one of their most eccentric designs from early in that era, the Yamaha B-6 power amp. His travails are documented in these two videos:
Yamaha B 6 Amp Part1 and Yamaha B 6 Part 2: Frustrated By The Frustum - Tony Meets his Match
I still have two Yamaha units from later on in the '80s that are still doing yeoman service four decades later, so apparently the Yamaha folks eventually pulled their act together, at least to some extent.
On the other hand, one of the better audio techs on U-Toob was stymied by one their most eccentric designs from early in that era, the Yamaha B-6 power amp. His travails are documented in these two videos:
Oeh. That B6 looks cool, now I want one....
"The Yamaha C-2 is a vintage preamplifier that was available from 1976 to 1978."
Wow! The gesign is so clean and modern, i would have guessed 90s at best but 70s? For real? It doesnt look vintage at all.
Shocked out how good that is for the 1970's. That is one of the things I have always loved about Yamaha claiming a natural sound. They mean flat with low distortion, which is exactly what you want from your devices.
Another excellent review. Thank you!
I also preferred Yamaha's clean styling compared to the glitzy look of most other Japanese amps, which I think were made to appeal more to the US market than the UK one.
This would be great if you have a turntable. I feel that separate pre-amps are a bit of an outdated concept though for most people nowadays.
I have the C 4 - my phono inputs went bad, so it's on the bench. Love it. Since prices are rising on these, I have to discourage people, same with Perreaux, and the likes. I do take them, if you want to get rid of such... ;)
Awesome review, NTTY
Cheers
The thing is back then, vinyl was regarded by most 'audio people' as being the best source we had, decent FM live-broadcasts being very much a minority interest I remember. i suspect this means that some VERY DECENT products went unnoticed over these parts as more 'characterful products' came along, playing up to vinyl (of the period) productions. What I'm trying to suggest is that the C2 would have been seen as very 'ordinary' as it's full potential was never really exploited in a typical domestic sound rig.
Yamaha did get more 'jazzy' as the 70s went on, the switches seemed chunkier and clunkier and rather useless meters became a feature, albeit discretely. The original CA 600/800/1000 models of the mid 70s were rather lovely though I remember.
Why would you need balanced in and outs? Are you doing gigs?
Well... a possible issue with today's audio that wasn't a thing in those days is the fact that today a lot of people use computers as music sources combined with external DACs. An issue that can occur (because of leakage currents in PC power supplies) is a ground loop resulting in weird sounds/noises and hum.
This also can occur with active speakers b.t.w.
This can be avoided when using balanced interconnects.
The best hifi has been made in the 70s and 80s. It was the time where there was a ton of research on circuits and materials and semiconductors and companies were willing to spend a fortune on R&D while taking risks.
Just look at the Sansui's for example, the bigger ones are still state of the art: https://audio-database.com/SANSUI/amp/au-x1-e.html
DC-500KHz in 1979 and there were many, many models they never exported outside Japan, X11, X1111, AU-Alpha and the likes.
Sony also had their line of extreme quality gear with the first ESPRIT - VFET transistors, SMPS and the likes, all in the 70s.
I still find all that gear unmatched when it comes to technology used and I don't think we will ever surpass it.
Now it's often just grey matter made to push money. More of the same, low-effort repackaged simple circuitry with the chip MFG's textbook example applications, few boutique caps and that's it.
It's just sad seeing a €2k DAC or CD player with a sad single op-amp in the output stage.
Show me current gear that has a fully DC coupled signal path, high speed non-NFB etc. these days...
In science, low effort does not mean low result. It is often better to follow exactly what a chip manufacturer has specified in its data sheet, rather than trying to re-invent the wheel. Importantly, audio companies are NOT chip/semi-conductor designers, and they should NOT be. Leave the circuit design to the pros who specialize in it, and those pros do not work at audio companies. The audio companies' job is to carry out the design through efficient management of the supply chain and logisitcs, which is what the Chinese excels.
