cay-uwe
- Joined
- Dec 22, 2025
- Messages
- 33
- Likes
- 78
I am opening this thread since I have been asked to post some of the measurements I made of my reacently refurbished YAMAHA B-2 amplifier and its matching YAMAHA C-2 preamplifier.
@NTTY posted already a very good review of the YAMAHA C-2 preamplifier and I was happy to see that his measurements pretty well correlate with mine.
Both units had defects when I bought them and it turned out that it was mainly contact problems of switches due to corrosion.
The YAMAHA B-2 had additionally brocken potentiometers that needed to be replaced with equivalents that were hard to find ...
The YAMAHA C-2 had severe corrosion problems at all selector switches which can been seen well on this picture.
I run my measurements to check the equipment and it is supposed to be for verification purposes.
Theses are my findings after I have repaired the YAMAHA B-2 amplifier.
The spectral analysis of a 1kHz sinus signal is actually very good and what I like is the low level hum ( 50Hz / 100Hz Europe power ).
Also the frequency response looks very good and it matches the published specifications by YAMAHA on their brochures.
The red curve is full range, the blue curve with a high pass filter at 15Hz and the following measurement is from YAMAHA.
The YAMAHA C-2 preamplifier was partially working when I got it and therefore I was able to run some measurements before repair.
The spectral analysis of a 1kHz signal looked very bad below 1 kHz since it shows a lot of power noise. Initially I tought I will need to rework the power supply and probably some capacitors.
I started cleaning the selector switches first, because some of the sources were not selectable at all, or only partially and after that I got this spectral analysis.
As one can see, once the contacts have been cleaned, all of the power noise was gone and that saved me a lot of soldering work...
Finally I also checked the frequency response for both channels, red = right, blue = left. I was impressed about the very good matching of both channels.
It had a difference of <0.1dB in three different positions, 1/4, 1/2 and 3/4 volume level. For a > 50 year old volume potentiometer that is very impressive !!!
As a teenager this equipment has been a dream and for me 50 years later the dream got reality. Still from todays standards it is fantastic ...
