Much too high a price, you can find a DAC or phono input (if absolutely necessary in 2024) for less than $100 very easily. The various signal-to-noise ratios take us back to the 1970s.
I voted for postman panther. For about half this price, you can have a home theater AM/FM receiver with Dolby Atmos. With rather close measurements I would say.
So the DAC measurement include the amp right? No directly comparable maybe to other DAC measurements on the forum.
I've owned one for years and my wife thinks it sounds very goodYou can hear the lifted veils from the kitchen.
I've owned one for years and my wife thinks it sounds very good![]()
How else is the internal DAC meant to be tested apart from using the analog pre-outs, like other integrated amps and AVR's?Correct. The review is botched in a number of ways.
No one is going to use this box to route its DAC externally. Testing it through the amp represents 100% the usage scenario.Correct. The review is botched in a number of ways.
It appears I missed this, no pre-outs.Unfortunately there is no pre-out so I can only test digital input when going through the amplifier. Then again, that is how you would use it.
Hello, please amend your post accordingly as that is a term we try to avoid here. Thanks in advance and for your understandingI'd rather buy one of these than a dozen of these little *redacted* amps that are rated with some 90's cheap car audio standard. I just can't do disposable.
It's not quite the same because the rec-out is a direct input signal without the influence of the tone control and volume pot that the pre-out has.I think John pointed out that there are two Rec-outs, which are in fact pre-outs.
Further, unsure if you're aware that most of the cheaper line Yamaha amps and AVR's are made in Malaysia and China? Best to focus on the product under review.![]()
Let's Avoid the Term Chi-Fi
I often see the use of the term "Chi Fi" to describe audio products from China. I see the intention and don't think anyone is trying to be racist and what have you. Still, I like us to show the highest respect to products from around the world. As avid readers of this forum know...www.audiosciencereview.com
JSmith
In fact, somewhere back a few weeks I posted some pics of a nice Yamaha RN-602 belonging to a good mate. He'd used it for years and then ~3 years ago, moved to a beachhouse 1 street back from the ocean at Nobbys Beach.
It's a write off. I can only bring it back from the dead as a normal amplifier- tuner/bluetooth/wireless/lan/streaming all dead from corrosion. All casework screws and panels have rusted. The big old through-hole components in the power amp stage survived and still work.
Yikes. This location sounds like a case for precautionary conformal coating if there ever was one. It may seem unorthodox to rip apart brand new electronics, but if it drastically prolongs their operating life it's worth it. Desperate times call for desparate measures and all.And his PCs need replacing every 2 or 3 years due to the fans pulling in salt air and destroying the boards from the inside out.
