Y-split the 12v trigger signal?
Ruediger
Germany
I was wondering, if I use a DAC with 12v trigger out. And two mono amps with 12v trigger in behind that. Can I just y-split the trigger cable to signal both?
If so, are there differences known with any devices?
Not a problem. The reverse (two devices powering one amp) needs a diode inline though.
Hi, shouldn't be a problem,I'm using y-split trigger cable from WiiM ultra to a pair of Purifi monoblocks work fine.
Thanks. I have a plethora of various Y-plugs lying around from the old stereo days. Trigger cabling all over is an easy job.
And I bet I'll find a one-way / dioded cable or plug for cheap on the net too.
I'm using af y-split from my NAD C3050 LE to my two Apollon Monoblocks. Works like a charm.
