Bought the cup and handle break put at 30. way too far away from its 200dma to risk an entry here unless we see further sideways consolidation
To a degree that depends on quantity and how you buy/stock your materials for such.....but since I do look to the future I tend to buy in sufficient quantities to definitely save money on making my own. Plus they can be exactly as long as you want them to be....
IMO the quality of the connectors is important. I don't want issues with mechanical failures or poor quality metals etc. You don't what you're getting with house brand generic stuff.
Neutrik XLR plugs are $2.50-$4.00 depending on color and Gold/Silver plated contacts. Amphenol makes quality connectors too. Mogami or Canare wire is anywhere from 60 cents to $2.00 per foot. Markertek has free shipping with $25 order. Watch a video on soldering and you can make far better cables than the generic stuff.
Based on what I see in the Amazon picture, it’s the same – nothing’s changed.Right, but in what way should a wire for data be different than one for audio?
You need to make a distinction between the Premier Monoprice cables and the cheapest version.Take a pass on the Monoprice XLRs – they use no-name connectors that don’t hold up. Here’s why:
http://forums.audioholics.com/forums/threads/what-brand-of-xlr-cables.96212/#post-1101917
This fellow confirms that Monoprice XLRs are junk too.
http://www.avsforum.com/forum/113-s...-sw-xlr-output-sw-rca-input.html#post51295009
Regards,
Wayne A. Pflughaupt
The Premiers are much better. They still don't have Neutrik or Amphenol connectors. But I've got a dozen sets and never had problems with them. I've used most of them for remote recording where they get dragged around, rolled out and up and used quite a bit. I now prefer thinner more supple cables for live recording. But for home use where there isn't much movement and such the Premier Monoprice XLRs are a good value.
The Monoprice Monolith XLR also appears to be better construction, but I've not used them personally. They are getting up into the price range you can get something with Amphenol connectors and Mogami wire.
Yes, it actually appears they no longer make the very cheap XLR with the silver ends that were problematic. Those that looked the same as Hosa uses. I've known people with the Hosa XLR's and the ends stop making reliable connection after as few as 5 or 6 uses.Their AES/EBU cables are serviceable as well, and well priced. The connectors are much better than the ones on their "audio" XLR cables, including the Premier ones. I have never used the Monolith ones, but also have no cause to do so. Also, 16AWG is gratuitous for line-level cables. I'd rather have thin and flexible.
From the photo you posted in your link it's clear that is not the cable or connector I recommended: https://www.amazon.com/Monoprice-Premier-XLR-Male-Female/dp/B003L18XKE/Take a pass on the Monoprice XLRs – they use no-name connectors that don’t hold up. Here’s why:
Regards,
Wayne A. Pflughaupt
I agree but don't forget to include the price of a good soldering station.IMO the quality of the connectors is important. I don't want issues with mechanical failures or poor quality metals etc. You don't what you're getting with house brand generic stuff.
... or have the color you prefer.To a degree that depends on quantity and how you buy/stock your materials for such.....but since I do look to the future I tend to buy in sufficient quantities to definitely save money on making my own. Plus they can be exactly as long as you want them to be....
I was speaking of the Premiers. Glad you’re happy with yours. The female variety of that connector type significantly wallows around in the socket, which means they will eventually fail. By contrast, Nuetrik connectors will hardly move at all. If you have some other XLRs on hand, might do a comparison. I've been dealing with pro audio gear for over 30 years, and I've seen tons of mic cables with those connectors bite the dust.You need to make a distinction between the Premier Monoprice cables and the cheapest version.
Yes, those do appear to be a big improvement over the Premiers.Their AES/EBU cables are serviceable as well, and well priced. The connectors are much better than the ones on their "audio" XLR cables, including the Premier ones.
Even though of the same design I wonder if they are better made or better tolerance in the shape of the connector with the Premier's?If you had read through the link you’d know I was speaking of the connector type - which is the same type the Mono Premiers use.
Regards,
Wayne A. Pflughaupt
Many years later, but BJC uses canare l-4e6s and so do at least some of the WBC cables. And neutrik connectors (though maybe slightly nicer neutrik line on the BJC).I've got quite a few around here and haven't had anything to complain about.
Blue Jean Cables does make a nice cable for sure.
