For folks like me with minimal electronics background some ultimate clarification would be useful regarding the connection of XLR input pins to an amplifier module, whether by Hypex, ICEpower, Purifi, Pascal or whoever.
Assuming the amp module supports balance input, (as most but not all), do. It's pretty obvious that Pin 2 of the input XLR connector ought to be connected to the module's V+ input pin, and Pin 3 to the module's V- input pin. But what of ...
But my observation of both Hypex and ICEpower modules, amp modules had a input Gnd pin, (as well as V+ and V- input pins). Further I've observed that standard wiring sets for these provide a shielded cable consisting of a pair wires connecting to the V+ and V- pins and a shield connected to the Gnd pin.
It's totally obvious that the respective wires ought to connect XLR pin 2 to the input V+ pin, and the XLR pin 3 to the V= pin. But where (if anywhere) does one connect the shielding at the far end of the cable from module input?
Apparently one does NOT connect the cable shielding to the XLR pin1 according to RANE et al. One then does one do with it?
Depending on this answer, then also, what is the purpose of the module's input Gnd pin? Is it purely to drain interference collected by the cable shielding back to the amp module rather than allow it to affect the V+ and V- wires?
How to connect a single-end, RCA, input to a module with V+, V-, and Gnd inputs is another question, but not one I'm posing at the moment.
- the XLR's Pin 1, and also
- the module's input Gnd (ground) pin?
