XLR cables are quiet individually, but loud hum when joined together — why?
Discharge
I’m trying to understand a strange grounding/hum issue in my hi-fi system.
I have two balanced XLR cables. If I use either cable individually between my NAD M66 and amplifier, everything is quiet.
However, if I connect the two XLR cables together in series to create a longer run, I get hum through the speakers. (I have changed from my old rack setup and need longer cables).
As soon as I separate them and go back to using either cable individually, the hum disappears.
The cables have male/female XLR connectors so they connect directly together — no separate coupler.
My understanding is that two correctly wired balanced XLR cables should effectively behave like one longer cable, so I'm wondering what could cause this.
Could it indicate:
  • A bad/intermittent Pin 1 shield connection at the cable-to-cable join?
  • Different Pin 1/shield or connector-shell wiring between the cables?
  • One cable having Pin 1 lifted or wired differently?
  • Something else I'm overlooking?
Could it indicate:
All of the above.
Try probing the cables with a basic multimeter set to continuity mode.
Okay i'll give it a go in the morning as im wreaked now, ive been pulling my hair out all night trying to work out where the hum was coming from!
