Sokel
- Joined
- Sep 8, 2021
- Messages
- 11,557
- Likes
- 12,775
It's not the robot, it's its colors!Oh common, it's fun, why so serious![]()
(yep, I'm as swallow as it gets)
Well, at least there's an anthropomorphic design improvement with clear orifice markings. Think of all the mistakes that could be avoided.Well apart from the novelty design, this is not great... I assume the owner got it for his/her kids and sent it in for a bit of fun.
I hope it brought a smile @amirm whilst testing it.
This is the back;
JSmith
I suspect the tube kicked off the rest of the design. Looks the part and novel for anyone born in the last decade or two.Great design, but unfortunately they just "had"to screw up measurements with that tube in it
I like the way techno gives my ears a massage when using headphones.Both. I don't listen to ton of it as it can be repetitious but do enjoy some. For testing, I use them as test of upper bass performance.
In one and the same DAC & HP Amp to be able to have the choice and switch between the tube sound, which you described as: ...But have that combine with vocals and they were quite gritty. As was the bass in techno music at elevated levels. During same passages, high frequency notes almost became unlistenable due to their harshness.Wish they had designed a tube bypass. It could come in the form of a bigger brain or something.![]()
To then be able to by pass the tube and get an uncolored, below threshold for hearing regarding SINAD choice. Maybe there is only a tiny potential market for such a DAC & HP Amp though?
Thanks Amir your review, detailed measurements and listening tests of the xDuoo DM-01 Robot DAC & HP Amp.![]()
Refreshing !
Thanks
Too bad they didn't offer a "Tube bypass" mode...
Performance is quite lower than announced as well (if that makes any difference): 1.2% THD+N vs 0.3% and 100dB SNR vs 116dB.
Talk about "In through the out door!"
