xDuoo DM-01 Robot DAC & HP Amp
Rate this DAC & HP Amp
    Votes: 95 54.0%
    Votes: 43 24.4%
    Votes: 22 12.5%
    Votes: 16 9.1%
This is a review, detailed measurements and listening tests of the xDuoo DM-01 Robot DAC and hybrid tube headphone amplifier. It is on kind loan from a member and costs US $237.
As you see, the product is aptly named! The arms are actually functional with one being on/off and then other, selection between USB and Bluetooth. The "ears" control the up/down volume control. The torso shows what you see with color changing depending on mode. Missed opportunity to have it be a graphics display saying robot stuff.
What follows is a bit of abbreviated measurements in the interest of time.
xDuoo DM-01 Measurements
Let's start with the DAC section, taking output from the rear aux terminal and setting the volume to 2 volts nominal:
xDuoo DM-01 DAC Headphone Amplifier Tube preamp, USB C Bluetooth Measurement.png
I had forgotten for a moment about that tube and was shocked at the level of distortion. That sinks the SINAD at the bottom of our 400+ DACs measured to date. Won't bore you with the graph.
Dynamic range though, was surprisingly good:
xDuoo DM-01 DAC Headphone Amplifier Tube preamp, USB C Bluetooth dynamic range Measurement.png
As was frequency response:
xDuoo DM-01 DAC Headphone Amplifier Tube preamp, USB C frequency response Bluetooth Measurement.png
Intermodulation expectedly, not:
xDuoo DM-01 DAC Headphone Amplifier Tube preamp, USB C Bluetooth Multitone Measurement.png
Headphone output partially redeems itself with good amount of power:
xDuoo DM-01 DAC Headphone Amplifier Tube preamp, USB C Bluetooth Power 300 Measurement.png
xDuoo DM-01 DAC Headphone Amplifier Tube preamp, USB C Bluetooth Power 32 Measurement.png
I was relieved that the output impedance was near zero:
xDuoo DM-01 DAC Headphone Amplifier Tube preamp, USB C Bluetooth power vs impedance Measurement.png
XDuoo DM-01 Listening Tests
When you get one chance to listen to a robot DAC, you take that opportunity! :) I only tested it with my Dan Clark E3 headphone. Despite its low sensitivity, the DM-01 had no trouble pushing a ton of volume out of it. At low listening levels, or when only bass was playing, the fidelity was good. But have that combine with vocals and they were quite gritty. As was the bass in techno music at elevated levels. During same passages, high frequency notes almost became unlistenable due to their harshness.
Net, net, if you don't listen too loud, it may be OK.
After measuring hundreds of similar looking black metal boxes, it is a pleasure to see an out of box form factor. Wish the tube was not there as it would make it much more performant and robust in the hands of younger people. Still, some may like the combination.
While I won't go and buy one for myself, the xDuoo DM-01 makes for a nice novelty gift or conversation piece on your office desk.
Share the DAC graph!
So from the output vs impedance graph, the headphone driver is good (not that we can see anything beyond -60dB), but the distortion is coming from the tube handling the higher signal voltage
Thank you for the review, @amirm
DM-01 got my Postman Panther vote but only because of the novelty of the design.
I could see someone modifying it [untubing it?] with a replacement Sabre ES9039 design, while retaining the same form-fit-function.:)
Other than the fun design, not much into it.
1.3 % distortion? Thank you, not in my system, not in my ears. I had enough of cassette players and sapphire piezoelectric pick-ups in my youth, not to take advantage of inexpensive 120 dB DACs and excellent SINADs in these better days. Excellent review of a flawed product, Amir!
Ah, those 'wunderful' euphoric harmonic distortions. Well maybe some people will like it. Reminds me of tube amps using 300B triode ;)
The great missed opportunity was to actually make it a functional HP DAC/AMP with good measurables which could have been done for little if any extra cost, by taking that stupid tube entirely out of the circuit and making it purely decorative.
Too bad, it would have been very cool to have that as a go to amp on the desk, but it needed to be viable for that to happen.
Great review, Amir.
