Wuzhi amplifier Bluetooth- Wuzhi app
Firefighter1990
Hello.
I bought the amplifier with Bluetooth ZK-1001B from Wuzhi. I want to change the Bluetooth name, which should work with the Wuzhi Audio app. As soon as I want to add the amplifier in the app, the app crashes. Does anyone else have this problem or am I doing something wrong? I am using an Android device as my phone. Thank you very much for your help
Hello.
Hi
Welcome to the forum.
Personally I have never heard of this brand. I've just looked it up, and it is not the typical type of device discussed here. You may find that no-one else on this forum has used it.
I would suggest contacting the manufacturer or supplier for help - or trying to find a user to user forum for this specific type of device.
Also try the usual app troubleshooting in android, such as clearing the cache, or uninstalling and re-installing the app.
EDIT : there is a thread here about the 1002 version. Perhaps ask in that thread, or DM some of the members there who own this type of device.
Hello.
Hi.
I faced the same issue.
It seems like the app isn't functional on devices that have an operating system higher than Android 11.
It works perfectly fine on my S3 Neo, but isn't on my S22 Ultra.
Besides, the app is very buggy and most of the features don't work properly. Like EQ or mode changing between AUX and BT.
I hoped that helped.
