Why? I just looked and it has the same glm in/out and the AES in/out of the 7360.No, as I wrote in the post just before the one you replied to the 7350 can’t be chained together like the 7360 and above, at least not if you want to use GLM.
So jealous. I did my report and it looks horrible. Ordered a bunch of acoustic panels from GIK.View attachment 207170
So much info!
How can I contact Genelec with questions? ThanksI'll ask Genelec to get a definitive answer, they usually respond in less than one day. I also see no reason why it wouldn't work though.
Can’t figure out where he got figure 3 and 4 from. I can’t find them in the Grade report.Some info and link to seminar this week
Interpreting GRADE’s room acoustic measurements - Genelec.com
GLM’s GRADE report provides a wealth of information about your room and your monitoring system, so this blog piece provides a practical illustration of how this information can be interpreted – and what simple actions can be taken – by focussing on the stereo imaging of your monitoring system as...www.genelec.com
Grade report shows the phase graph for my 8351A but not for my previous 8350. What model do you have?Can’t figure out where he got figure 3 and 4 from. I can’t find them in the Grade report.
I wish they would talk more about early vs late reflections. How those are measured and that number means.
Otherwise I get the impression that the more your cover your walls with acoustic panels the better that number will get.
From the GLM 4.2.0 Release Notes the Genelec GRADE feature is something one has to pay for after 2022:
>>>The GRADETM Room Acoustic Report is a new service that uses all the information collected
automatically during GLM AutoCal’s process to create a detailed PDF document that
analyses monitoring system performance. The report will help users and studio designers
alike to fine tune the room’s acoustic treatment, adjust monitor and listener positions, and
optimise bass management. As an introductory offer, the report is available free of charge
throughout 2022<<<
8341aGrade report shows the phase graph for my 8351A but not for my previous 8350. What model do you have?
Get the largest subs you can afford.I will say one thing about Genelec subs. They are expensive for what they put out. However the flat in room response I get is priceless. No headaches either. I could put one behind me and GLM will time align and phase align it. It’s extra outlay in the beginning but the pain of paying for it will subside leaving you with a nice headache free scalable solution.
I was going to go with 2 x 7350s but decided to just get a 7360.
I found out while testing some Grateful Dead that the sub can clip even sitting in a corner and calibration cuts quite a bit to compensate for corner reinforcement.
So here I am contemplating calling Ryan at Front End audio to order a second.
If you really think about it, the 7360 only has a 10” woofer. The whole sub is sizable but the driver is actually small.
In room with room reinforcement I get extension to 19.4Hz. More than enough so the 10” goes deep enough it just can’t keep up on all music.
This is something to think about when choosing between a 7350 and 7360. Perhaps 4 7350 may be the way for someone who picked a 7350. Of course you could also mix and match.
Just things to think about. I was surprised to see it clip like that. It also clips inaudibly thanks to how GLM works. If you are in any way OCD about your audio equipment- plan accordingly.
When the single 7360 was clipping what was SPL @ listening position and how close are your monitors to listening position? Apologies if you stated this already upthread. Thanks.I will say one thing about Genelec subs. They are expensive for what they put out. However the flat in room response I get is priceless. No headaches either. I could put one behind me and GLM will time align and phase align it. It’s extra outlay in the beginning but the pain of paying for it will subside leaving you with a nice headache free scalable solution.
That's weird, I thought all modern models would get that info in the GRADE report but the logic is obviously different. Try using Multipoint measurement if you don't already.8341a
