I think I already saw the first chart linked here but not the whole document. Gonna dig it, thx!
That's a pity, I thought using the AES/EBU in/outs could do the trick...
No, as I wrote in the post just before the one you replied to the 7350 can’t be chained together like the 7360 and above, at least not if you want to use GLM.you could use 2 x 7350 but they are considered to be small for the 8350.
I suppose that in specific scenarios 2 X 7350 maybe would be better than 1 x 7360 (I am talking in general, not specifically for the 8350)
Knowing that, do you think I can plug one sub on the GLM network, set it up then store the settings to unplug it and repeat the process with the other sub?No, as I wrote in the post just before the one you replied to the 7350 can’t be chained together like the 7360 and above, at least not if you want to use GLM.
I don’t think so as all monitors and subwoofers have to be connected at the same time.Knowing that, do you think I can plug one sub on the GLM network, set it up then store the settings to unplug it and repeat the process with the other sub?
I'll probably order on Thomann or Woodbrass, the only issue is that both sites announce that the sub isn't available yet (14-18 weeks delay for Thomann...). This gives me plenty of time to focus on the acoustical side of things in the meantime![]()
I don’t think that will work with GLM, and if GLM can’t be used there is no reason to buy Genelec subwoofers as there are other subwoofers that are cheaper, has better performance and looks much better as well.I am not talking about daisy chained subs, but for 2 seperate single subs, either in stereo or mono configuration
It's not the support list, it's an example sheetView attachment 207518
Not too bad. It doesnt take into account the W371 yet but I am sure it will come.
So it must be possible after all... The choice between 2x7350 and 7360 is still not clear for me, both solutions seem interesting.Here there is a post with measurements from a setup with 2 X 7350 and GLM
https://audiosciencereview.com/foru...re-and-the-7350a-subwoofer.31918/post-1126713
Yep will do!I would send an email to Genelec support and ask of it possible like you intend. The 7360 discusses use of multiple subwoofers (as it has a connector for it) while the 7350 does not.
This is so in front of the competition one can get . Genelec is now leading the hifi industry into the future. Impressive.This is way beyond what I expected. Wow! These guys are truly pros.
Thats true, - but you need some measurement skills, some gear, and a knowledge what to measure and why. In the GRADE report, Genelec have already done that learning time for you.While grade is impressive and convenient with some time and effort everyone can do the same measurements.
I concede as it's the truth, even is studios and those who can measure would enjoy the convenience of GRADE.except you and I and maybe some enthusiasts who has a fetishism for measuring things ?
