- Joined
- Jan 27, 2019
- Messages
- 7,315
- Likes
- 12,264
Hey folks,
I use Conrad Johnson Premier 12 monoblock tube amps and recently got hold of another pair to try out. (Long story).
I've been switching back and forth testing them out, different tubes 'n such, but it is a bit laborious. I power down everything, switch over the speaker wires and RCA signal cables, power up...
However my preamp(s) do have two sets of main outputs. If I bought a few more, longer interconnects I could have both sets of amps permanently hooked to the outputs of my preamp, and then IF I KEPT THE AMPS POWERED UP I'd just have to switch the speaker cables between each set of amps.
So the question is: Can I do this while both sets of amps are powered up? What if anything does that risk to the amps?
It would obviously mean:
1. At any one time, one set of tube amps will be powered on but without being attached to speaker cables.
2. Plugging and unplugging speaker cables in to amps while they are on.
3. Possible risk to the speakers themselves of having the signal plugging in/unplugging from the amp while the amps are on(?).
My foggy memory is telling me you generally don't want to do this, that tube amps especially don't "like" being on while not hooked up to a load, and that maybe plugging in and unplugging speaker cables with the amp on is a bit risky. Basically, you'd want to power down, as I have been, to do switching like this.
I sure as hell don't want to risk anything happening to the amps or speakers, so I'm looking for some insight here from more electrically knowledgeable folks.
Thanks!
Thanks!
