This is the only forum that actually gives a damn about class D amps.You're asking the wrong forum...
I recently bought the AO200. It should arrive here in Brazil in about 10 days. It will be my first experience with a class D amplifier.I have an SMSL AO200 and also an Aiyima A07.
SMSL AO200 sounds better and handles certain types of speakers better and doesn't heat up at high volumes, it's a more complete and well-made amplifier and I don't see any flaws.
When SMSL A300 arrives on Amazon Italy I would like to buy it to hear if it sounds good and above all if it is more powerful
Thank you for the general description of the Sabaj A20s 2022 and above all for the comparison between the other devices. This type of information is very important for anyone who is researching appliances to make a purchase decision.It has been running continuously for 48 hours, but no problems have been found so far. The sound quality is also very good. Here are some of the things I'm interested in with the new amps. The amplifiers to be compared are SMSL AO200 / DA-9 / SA300, Sabaj A20a / A8, Topping PA3 / PA5, AIYIAM A07, etc. purchased so far.
There is no pop noise when the power is turned on and off. It's zero.
White noise (his noise) from the speaker when the music is stopped can be heard slightly when the ear is in close contact with the speaker unit. But I can't hear it at all 20 cm away. This point is slightly larger than Loxjie A30 and SMSL AO200 / DA-9. However, it is an extremely low level compared to conventional class D amplifiers.
The volume control of A20a 2022 adopts the conventional volume pot, and I am worried about the gang error when the volume is turned down. SMSL AO200 / DA-9 / SA300 etc. use JRC's NJW1194 electronic volume, so there is no gang error. Also, by using NJW1194, you can use the EQ function and tone control built into the chip, but the A20a 2022 does not have these functions.
The fever is a little hotter than the SMSL AO200 / DA-9. It's not as hot as AIYIMA A07.
BT is equivalent to SMSL AO200 / DA-9. It is a little inferior to the BT of the latest DAC. It seems that the BT module uses a product with a lower grade than the DAC.
The A20a 2022 does not have the abnormal noise from the power supply unit or the abnormal noise of the speaker output that I reported on the Sabaj A20a.
Similarly, there is no fluctuation in the DC offset voltage of the speaker output and pop noise that I reported in SMSL DA-9.
The DC offset voltage of my A20a 2022 is Lch-2mV / Rch-2.7mV, which is extremely small and stable.
The output power of the A20a 2022 is 170W (4Ω) / 90W (8Ω). It has more than double the output power of AO200 / DA-9 / SA300 / PA3. High output is possible with a dual power supply with a power supply voltage of + -34V (total 68V) for the MA5332MS chip. If you feel power shortage with AO200 / DA-9 etc., A20a 2022 is the best choice.
An amplifier that uses two MA12070 chips, such as the AO200 / DA-9 / PA3, has twice the output of one amplifier. But that's only when you connect a 2Ω load. When a 4Ω / 8Ω load is connected, only the same output as one amplifier can be obtained. This is the point where it is easy to make a mistake in the circuit operation of PBTL.
SMSL has an A300 that uses the same amp chip. This product is a MA5332MS amplifier product that has the same functions as the AO200 / DA-9. Functions such as electronic volume, EQ, BT, and USB are the same. You can also use the remote control! I would like to purchase and test this SMSL A300 after this. However, I don't like the cheap iron plate housing of the A300.
Using the A20a 2022, I think the Infineon MA5332MS is a very exciting amp chip in the future.
I can't say for sure about the sound quality yet, but it is a very clear and high quality sound similar to AO200. I feel that the bass has become a little stronger.
Switching between BT and RCA inputs is done with a small switch on the back, which is a bit difficult to use.
SAbaj A20a 2022
Sabaj Audio Official-Sabaj音频官网
Since the establishment of our company, we have been committed to an enterprise integrating audio product design, R&D, production, market operation and service.There are mainly three categories: decoder/headphone amplifier/power amplifier. Our company is composed of a group of members who love...www.sabaj.com.cn
SMSL A300
A300
Foshan ShuangMuSanLin electronics Co., LTD. founded in 2009 which located in Shenzhen, China. And our branch company VMV Technology(HK) Company Limited registered in HK in 2013. Our company is specialized in the audio DAC, stereo headphone amplifier, power amplifier, and with own R&D...www.smsl-audio.com
"About the problem of gang error"
This problem applies to most amplifier products in China.
The problem is that they are using the wrong volume pot for volume control on their audio equipment.
For the volume pot for volume control, it is usually necessary to use a taper A characteristic whose resistance value changes with a logarithmic curve.
However, Chinese companies use taper B volume pots whose resistance changes linearly.
I have previously pointed this issue to several manufacturers in China, but they didn't have any knowledge of Taper A and Taper B and couldn't understand my point. Only Chinese manufacturers use Tapered B for volume pots for volume control in the world.
I was surprised that many audiophiles these days don't understand this.
"Adverse effects caused by using Taper B for volume control"
1. 1. The volume suddenly increases just by turning the volume knob a little.
2. 2. When the volume is lowered, the difference in volume between the left and right (gang error) becomes extremely large.
Toku, I think SMSL A300 is better than Sabaj A20s 2022, apart from the lameria that you don't likeI bought the Sabaj A20a 2022 shortly after launch and am currently testing it.
SAbaj A20a 2022
SMSL A300
A300
Yes, I think so too.Thanks @Toku ! I've ordered smsl a300 , I have topping MX5 with older chip to compare. I would rather to have all in one box ( like MX5 ) but for that price amp only with sub out, remote and this power looks like a bargain!
I bought both the A20a 2022 and the A300 and set up the BTL mono mode on the A300. It is well worth trying in terms of sound quality.Ordered my a20a 2022, can't wait for it to arrive. Have anyone used them in BTL mode? How do you like it?
