He swapped the magnet polarity. That's patent-worthy innovation, right?
Are they trying to reduce diffraction from the cabinet (that a woofer would play?)Hi MattHooper,
Does it look like B&W is trying to place the 805 D4 woofer in a pipe? The tweeter is already in a tapered pipe.
I put transducers in pipes. Pipes are great for DIY.
https://www.linkedin.com/pulse/copy-my-retirement-project-part-1-steve-mowry-n848c/?trackingId=ZD1bQMhyLj/1LR8GdJmCTA==
As a min, we should promote a boycott of Borresen loudspeakers and the related snake oil products.
I went a step further and threw mine out of the window, an expensive loss, but that's life... By the way mine where the first of the even newer generation, not ironless but membraneless!Alright, if that’s what needs to happen, I’ll boycott Borresen. I’ll do it for the community. It’ll be hard, but I’m determined to cope. One day, I’ll probably look back on this journey as one that helped shape me.
The Audioholics video about the B&W 801 D4 Signature is here: https://rb.gy/9vo9em
Primarily informational on the tech and history of B&W, Gene gives these high praise.
He also shows measurements in a treated room (at a store) with no EQ:
These definitely do not belong in a "worst measuring speaker" thread!
Why is a measurement at 1 meter more revealing than an in-room measurement at the listening position?Stereophile measurements of the B&W 801 D4 Signature are here: https://www.stereophile.com/content/bowers-wilkins-801-d4-signature-loudspeaker-measurements
These measurements are far more revealing of actual performance than any in-room measurements would be.
Some +/- 2.5dB isn't that bad, neither the slight raise towards the upper registers. Probably that is all about room gain in the lower mids. Extension is straight down to 30Hz which is well preferred by many.These measurements are far more revealing of actual performance than any in-room measurements would be.
Those in-room measurments are making me think that B&W has been getting a bad rap here.
The spinorama's of-axis, predicted (not real that is!) in-room response is taken way too serious by some way too often. To those, please consider to get a microphone at hand (buy, steal or borrough). Measure "in-room" at one concrete position, measure somewhere else, like 1 foot away, compare, wonder.
Almost as good as the intro to Second City TV!I went a step further and threw mine out of the window, an expensive loss, but that's life... By the way mine where the first of the even newer generation, not ironless but membraneless!
A good in-room curve does not guarantee good sound.
Didn't claim such.Neither does a good on-axis curve under anechoic conditions in 1m alone.
Exactly, directivity matters, unless someone is listening under anechoic conditions.If any FR measurement could help determining balanced sound in my understanding, it would be taking on-axis as well as listening window behavior into consideration just as much as indirect soundfield linearity in the room, plus the level balance between the two.
Yes, the high directivity at the presence region makes them not sound harsh even with non euphonic recordings, a kind of a BBC dip.Most of 3-way B&W concepts with a top-mounted tweeter and low-order x-over filters seemingly result in a specific directional behavior making the result very room-dependent in the treble region, i.e. higher directivity index between 1K and 3K as well as pretty low index above 5K, with some bands dominated by interferences in between.
Didn't claim such.
... and still there are deviance by a dB or even two in predicted versus real in-room (which?!). The room may have a thick curtain hanging just where a nasty peak in off-axis response comes up and so forth. Wasn't that the purpose of room treatment to begin with?You can do both. < 500 Hz is dominated by room resonances (as always).
Damn, you came out swinging. Edit: you even made him delete that post. Well done.I noticed that you guys were bashing Børresen within this thread. I might be able to help out.
Michael Børresen was on LinkedIn puffing and complaining about patent offices.
https://www.linkedin.com/feed/update/urn:li:activity:7313594732541050881/
Then I added my comment below his post.
Respect must be earned. This guy is a joke! I can add this to my lists of stories.
https://pearl-hifi.com/06_Lit_Archi.../Mowry_Steve/Air_Core_Tweeter_Magnet_Assy.pdf
Voice Coil is an industry wide publication and it's free. What is the probability that he reads Voice Coil? Please wait while I integrate.
