- Thread Starter
- #1,081
Universal condemnation might actually force companies such as Borrensen to pull their socks up, although I very much doubt that.
Aha, Raidho you say. Have these speakers from Raidho already been brought up in the thread? Otherwise, check out these:Michael Børresen and Lars Kristensen, heads of Audio Group Denmark, where the original founders of Raidho. Kristensen had a past in Nordost as well. According Roy Gregory on The Audio Beat, Raidho original designs were affected by similar issues. Then, Raidho collapsed in 2009 and was took over by Dantax (a solid audio company of Denmark) that restructured the brand and brought it to a certain success in the following years. Børresen and Kristensen were re-employed under Dantax. At some point, the Scansonic brand was launched as a more affordable spin-off of Raidho. Finally, the two parted ways with Dantax/Raidho and went on with their new ventures. It seems the two are very good marketers, but lack a track record in electroacoustic engineering. Børresen's ideas about speaker drivers are somewhat eccentric and do not make much sense to me, besides the fact that they seem to misuse terms like "induction" or "hysteresis". I simply believe their beliefs are totally detached from common wisdom about speaker design.
What parts of this speaker are satisfactory or good? Are there not better speakers that at least match it in those areas and cost less?Well, that depends on whether you care about truth and nuance, over simple dichotomies “ good or bad” based on a personally selected objective criteria.
What exactly is wrong with being able to say:
This piece of audio gear or loudspeaker “ sounds like this..,?” (supported by measurements.). And if one needs to use good and bad criteria, “has poor performance with respect to A,B,C… but satisfactory or very good performance with D,E,F?
To me that is being informative. More informative than just “ the speaker is designed broken.” It still leaves somebody just as free to look at that and say “ for my purposes, that speaker is trash.”
I find for instance even my own friend’s impressions, recognizing some of the deficits, but telling me the reasons the speaker was nonetheless lots of fun to listen to, is more interesting and helpful than “ it’s a broken speaker.”
I think you are giving the impression Erin's review is better than it is of the Borreson.
I'm at a loss to see why you are on some crusade to take up for this.
I also think you are painting a worse picture of what ASR members as a group do in judging speakers.
What is the point of having learned what separates good designs from excellent and very clearly what is poor if we in the end say oh well, somebody will have other ideas and like this. Or it may be very poor in measurements, but it doesn't sound that bad
Did you watch the same video I did? Did you see where Erin puts up the results of the Wharfdale Super Linton, and says, "it retails for $2500/pr with stands. You can see how much more linear it is. It will sound more natural, more neutral and more accurate than what you get with this." He goes on to show the waterfall plot with the bass ringing even though he usually sees no reason to even show that plot in reviews. It has three resonances, but the 80 hz one he said is the worst he has measured or heard to date. And it matched what he heard from the woofer. I mean we are way beyond some critique of black and white ratings here.If I am, that seems like a subjective assessment on both your or my part.
I think it’s very clear from any viewer having followed Erin that he would never buy this loudspeaker. But he did his best to point out what it does well and what it doesn’t do well.
I just don’t understand why that is a problem.
I mean his review tells YOU all you need to know, right? Do you need him declaring to you “ don’t buy the speaker?”
He likewise tried to give any viewer the information they could use in, deciding whether that speaker was still of interest.
I think you did a terrific job describing the nature of the speaker. Job done.
Some people don’t necessarily want speakers judged on a “ good or bad, buy this or don’t buy this” basis. They want to know how a loudspeaker performs and have that final judgement left up to themselves.
What exactly is wrong with that?
I don’t mean to, and I am trying to avoid that.
That’s why I carefully wrote:
The more vehement reactions to the measurements of this loudspeaker on this site don’t necessarily acknowledge this wider picture.
and I was responding directly to somebody who, I think, was going in that direction direction with a characterization of the loudspeaker that seemed to imply, it would sound worse than it probably does.
Because declarations that are design is good or bad just brushes past details and nuance that are actually informative. Do we want to know only broad strokes about how gear performs, or do we want to understand in greater detail?
Take a hypothetical speaker review: It’s informative to look at a design and observe for instance “ it has some unwanted deviations in the frequency response which is bad” but “ look here, the distortion at high volumes is very low, the pair matching of drivers and design results in very precise imaging… and these are actually good things.”
It’s not all just black-and-white.
And Erin did a good job of elucidating what the speaker did well and what it did poorly. As I say, this is more informative than just “ it’s a bad design.”
How does anyone watch his review and think Erin is saying this speaker is okay?
I mean, I get having taste for a speaker that is brighter or darker or whatever, but this is just broken. That 80hz peak makes things sound chesty and thumpy but in my experience with a speaker with a hump at a similar region (ATC SCM25As) it's not particularly natural sounding - just over emphasized kick drums and the like. But this peak, unlike the ATC's, is also sharp enough that it rings like a bell. This is of course disregarding the socking great resonances at 2-300hz and at 2KHz, the massive directivity error throughout, the fact that it has a wild impedance curve...In case that is aimed towards what I’ve been writing: my main point is certainly not that people would choose this loudspeaker and blind testing over a Neumann or Revel speaker.
It’s that the speaker may not sound as horrible as people imply when looking at the measurements. A lower blind preference rating would not equate to “ sounds just as bad as a couple of drivers placed on a table.”
This is where across-the-board ratings of “ good or bad” isn’t particularly helpful for understanding how individual loudspeakers actually sound. One should be able to acknowledge if a speaker is doing some things pleasingly, even if not other things. As Erin does. And that it’s not always easy to precisely predict how loudspeaker will sound with a certain range of music.
I think it’s also worth noting: There are plenty of people here who have made their own particular compromises, which are not compromises other people are happy making. And that includes within the span of people generally seeking accuracy as well.
You're right,I should specify.A lower blind preference rating would not equate to “ sounds just as bad as a couple of drivers placed on a table.”
Raidho TD3.8. $103,000 (pair):
View attachment 407485View attachment 407486
Raidho TD3.8 loudspeaker Measurements | Stereophile.com
Sidebar 3: Measurements Due to the Raidho TD3.8's bulk, I wasn't able to bring it up the stairs from the driveway to our living room, where I usually measure loudspeakers. I therefore measured the speaker in the driveway, keeping its front baffle turned away from the sun so the drive units would...www.stereophile.com
Raidho D-2.1 for £37,995-£41,995, or around $50,000 (for a pair? )
Raidho D-2.1 loudspeaker Lab Report
Raidho claims an 89dB sensitivity for the D-2.1 but that is remote from the 83.0dB pink noise figure we recorded. Impedance could have been reduced to increase this somewhat but Raidho appears to have preferred to make the D-2.1 a little easier to drive than many modern floorstanders. Although...www.hifinews.com
FR on those speakers looks terrible. As the icing on the cake in this crazy "High-End" segment, of course a hefty price tag for them.![]()
I would. If someone says "this design is broken" I would (likely correctly) assume that its performance is exceedingly poor.I just wouldn’t find the opinion “ broken” to be very informative as to how the speaker performs.
Because measurements aren't that simple. MD, short term compression, phase response, etc are all really useful measurements that don't usually come up in a standard suite.I am far more interested in establishing why people claim to hear differences between nearly equally great measuring speakers when their measured patterns seem near identical at +/-1dB here and there.
This is more of smile like someone with a couple of teeth missing and a scar on their upper lip causing it to droop asymmetrically. Not even a good smiley face.Klipsch has historically been the king of boosted bass, boosted treble, midrange holes and they have been in business forever. It lets me know that many of you guys like the smiling curve speaker, like your speakers smiling at you
with midrange holes.
I guess Borresen plans to keep smilingand stay in business like the vast number of smiling speakers.
Smiling curve fans can never be rehabilitated. They grew up that way. The smiley speaker seed was sown at a tender age for such guys.
