Worst measuring loudspeaker?
"I enjoyed JA’s summation.
’The Sasha V's measured performance is very similar to that of the Sasha DAW,"
JA's summation is objective and clear. Are you are asking for a more subjective and emotional response? :facepalm:
There's always going to be a clash between the ASR and Stereophile approach. ASR tends to be about weeding out "good" from "bad" speakers along a specific criteria, and generally "don't waste your time with the bad speakers."
Stereophile remains interested and open to a wider array of speaker designs, more of "there's all these speakers out there, they sound different, we'll tell you how they sound" rather than merely rank them on a specific criteria.
I see merit in both approaches.
Have you seen the latest Stereophile review of some dac or other where one of the old farts links to an expensive USB cable within the first paragraph, what is that all about?
But one approach is entirely dependent on
- the hearing acuity of the reviewer (of which we know nothing as they don’t publish their hearing test results!),
- the room they are in,
- how they placed the speakers in that specific room,
- their own biases (again of which we know nothing),
- how they are feeling the day they do the listening and their mental state
Or, we can run a dispassionate, jargon free, consistent, repeatable, controlled test which will tell us something meaningful about the speaker and how it might perform in our own environment .
What specific value does the first approach offer over the second ?
That’s all well and good right up until Sphile makes them their speaker of the year
When you can buy good speakers and EQ them to sound like bad speakers what's the point of bad speakers?
I don't think you can create every sonic difference between speakers just using EQ.
All of which can be overcome, I find. This idea that all such variables means you won't possibly hear the sound the reviewer described is nonsense, in my experience.
What you call "jargon" is to me, often enough, information. Subjective description can often be informative.
Sure you can use that approach too.
Different approaches and attitudes render different results.
Things are made easier if you adopt a "good to bad" rating based on a certain measurement criteria (e.g. a desired on and off axis response). You can say "if I buy a speaker with those measurements it's likely to sound 'good.'
But given the huge variety of speaker designs on the market, given all the combined ways speakers can measure and sound different, if you actually want to know "what each of them sound like" that's another thing. Correlating speaker measurements to precisely the subjective impression they will create - "how it sounds" - is far from easy. Even very experienced people can be somewhat surprised in the listening tests vs the measurements - e.g. "I thought that peak or dip would be more obvious than it actually sounds when using the speakers."
If you have adopted a specific "good/bad" criteria, you are less likely to give much credence to a speaker that would rate poorly on your scale, and so dismiss it. And also, people who rely heavily on measurements tend to not bother much with (or don't have much facility with) subjective description.
And a perceptive listener may pick up on characteristics they and other audiophiles care about, even in a speaker that doesn't measure ASR-approved. And then they can put that character in to words so the listener gets an idea of "what it sounds like" and how specifically each loudspeaker's character affects the sound of different music.
So instead of a method that is used to dismiss many loudspeakers, the less overtly judgmental method is "I'm going to convey in words what music sounds like through X,Y and Z speakers, and some of you may like either of those speakers."
This wider openness to speaker designs, as well as some audio reviewers being perceptive about, and motivated to describe, the sounds means that some "positive" characteristics that go overlooked or dismissed here will be conveyed. I've heard a number of loudspeakers that are derisively dismissed on ASR, but which subjective reviewers took seriously, and identified characteristics I'm very interested in. So there are plenty of loudspeakers I discovered and loved via the subjective review method that would never have happened in reading a site like this.
Most reviewers have compared many loudspeakers in the same room, and so have an apples to apples comparison in that regard, in terms of identifying different sonic characteristics. Remember too that, while yes rooms influence bass, Floyd Toole points out we have evolved to "hear through" the acoustics of a room to the sound source. That's why someone's voice doesn't become suddenly unrecognizable just because you hear them in different rooms - you still identify the character of their voice, vs someone else. Same for identifying certain constant characteristics in loudspeakers. Many times I've heard the same speakers in different rooms, and the basic sonic traits remain essentially the same. E.g. Quad 57s sound like Quad 57s in any of the many different rooms I've heard them in. Speakers I've heard at other people's house, and in audio stores, sounded in my room essentially the same. I sold a pair of speakers to a reviewer friend: they had all the particular sonic characteristics in his room that I liked in my room.
And reviewers are used to testing speakers in various positions in their room, so they often do manage to get something close to "the best" out of a speaker, and have an idea what is going on with their characteristics.
Finally, I pay attention to whether a reviewer has been accurate in describing speakers I myself have owned or heard before. If they are nailing the sonic attributes, and are perceptive about traits I care about, that increases my confidence in their impressions of other loudspeakers. (The same goes for zeroing in on any audiophile's descriptions, in forums). And I can triangulate one reviewer's impressions with other reviewers. And with audiophiles on line, to see if there is some trend in the descriptions. Taken all together, I have found subjective descriptions of loudspeakers pretty predictive in what a speaker sounds like, and I've had many successful purchases based on subjective descriptions. As well, I've helped others arrive at very satisfying purchases, based on my descriptions.
Of course, if you are inclined to think subjective description is just useless "jargon" you will not be inclined to put the type of effort in that could make it useful. Tools can only be useful if you use them.
At the same time many are now mainly internet based and thus free, so advertising is their main and for some only source of income.
I've never worked in the magazine industry, but my understanding is that magazines and newspapers were always 99% funded by advertising anyway.
But when they were paper based you typically paid for the magazine / newspaper as a customer too, so I doubt it was 99% advertising.
My understanding is that the "newstand price" basically just gave the physical store financial incentive to dedicate shelf/rack space to your publication. example - they pay $0.25 for a $5.00 magazine and get to keep $4.75 for every one they sell.
(Which is one reason why Craigslist really helped "kill the newspaper" by taking away the revenue from classified ads. It was always so ad-driven.)
Those aren't exact numbers but I'd always heard it was something like that. Maybe somebody with more direct experience can provide a more authoritative answer. Maybe I'm totally wrong. Either way we learn something. :)
The keyword is might sound in our own environment. I owned three Bag End M6 which measured very flat (however now they're no longer showing the measurement graph on their page...(hmmmm?). I bought them from my son who was using them in the nearfield, took them home and they sounded like garbage to me in the mid/farfield. Those speaker cost $699 back then (they're 899 and mine had a custom auto finish applied to all 3) sold the lot for $500. I've had speakers that measured well - (Infinity prelude P-FR's) and they sound great in my space (after some eqing). Then I've had the Whispers, that don't measure the best in my room (there's a crossover dip at 250hz), but they're the best sounding speakers I've heard in my space. Everything you've stated is true, on both sides of the coin. However a speaker that measures "perfect" in an anechoic environment my sound poorly to the damaged ears of an audio enthusiast, with a less than optimal listening space that has their own listening paradigm developed from their own listening habits and preferences. Chefs say hard cooked eggs are over done, however that's the only way I will eat them ....not runny, not soft, my eggs must bounce and have a little golden brown crust to them....because that's my paradigm.
Did the Alta Audio Adam speaker make it in to this thread yet?
Hoo-boy! Those have to bee some of the messiest measurements I can remember seeing!
It always amuses me that their reviewers can clearly hear the difference between cables and all manner of snake oil, but never egregious issues found in measurements. If only there was a simple conclusion to be drawn from this.
Perhaps the reviewers don't really know what they are talking about?
Well, audibility of port resonances that are extremely narrow band is probably quite program/music dependent. You have to exactly hit that frequency to excite it.
JA is close micing the vent which doesn't perfectly represent the farfield behavior and may further exaggerate the presence of these in the measurements.
Still, I would agree on this one. Mike from Alta seems very friendly and nice reached out to connect on linkedin and wanted to discuss his patent pending bass technology and I didn't respond further to that offer.
Two under-damped transmission line resonances, looks like. Very impressively chaotic, you normally don't see TL resonances in the mid/treble.
"The Alta Audio Adam's measured performance is a mixed bag. The enclosure is well-damped"
"The resonances in the transmission lines that load the midrange unit and woofer may look worse than they sound"
Hmmm...what does damping do in a transmission line...
