sam_adams
- Joined
- Dec 24, 2019
- Messages
- 976
- Likes
- 2,368
I like a fresh Canadian rye loaf. It goes so well in so many ways.
Rye is a good choice with any of the salted and cured meats.
Meat! GarwooowlZzzz. I like meat. I buy like a dozen slices of meat to nibble upon on the way home near every time I go shopping. It's a meal.Rye is a good choice with any of the salted and cured meats.
Thanks for the link, that does indeed pull in data from more sources (although still quite limited for floorstanders).You’re looking for https://pierreaubert.github.io/spinorama/index.html
Well the DI for the 802N is pretty bad for the price, and it is rather bass shy (or mid forward) depending on how you draw the PIR line. The HDI3600 has a pretty wonky frequency response and some DI issues. The F226be is good on DI and FR, but a bit bass limited for the price ($7000/pair).Thanks for the link, that does indeed pull in data from more sources (although still quite limited for floorstanders).
If we just look at the numbers, the gulf in performance seems to be not as great as some would have you believe.
The non be modells seems to give much more bang for the buck ? Quite a markup for be , but custommer seems to buy them ? Pricing is quite an weird art form ?Well the DI for the 802N is pretty bad for the price, and it is rather bass shy (or mid forward) depending on how you draw the PIR line. The HDI3600 has a pretty wonky frequency response and some DI issues. The F226be is good on DI and FR, but a bit bass limited for the price ($7000/pair).
The F208 has the DI and PIR of the F226be, more bass than the HDI3600, and no other problems in vertical directivity, power handling or compression. It’s also less than $4000/pair. I listened to them at a local dealer last year. If I wasn’t so into weird speakers (see my sig) these are the ones I would buy.
Now that me and my room got to know each other a litlle better I would choose none of the two.Which of these would you choose? It's a matter of taste and need. Maybe also the aesthetic, the looks.
Agreed. It does depend on the place where you live. In Europe Genelec, Kii and other European brands are probably a better buy than in the US (where Revel is a better buy).I suspect that availability and cost are very different in the UK vs USA, and that this significantly changes the performance for the money equation. (Especially when looking at used speakers).
Local access to parts and service is also likely very different here.
This could be part of the explanation as to why B&W has historically been better received in the UK press (not that I trust a word that is printed in What HiFi etc now). And why we hear so often comments like 'I don't get it, these are hugely overpriced' from those based in America.
Looking at current used prices in the UK, Revel speakers are generally unobtanium! I can find a single pair of ex-display F228Be speakers for £8999.
I can only find the F208 mentioned above new, and they cost £5399 here. The F328Be cost £15995.
Looking for used B&W 802's (which, are still much rarer than lower B&W models here) there are several options for less than £6000. (I know, it isn't exactly fair to compare used and new prices, but we just don't seem to have many used Revel speakers on the market here).
(Like everything else, all of the prices seem massively inflated over the last few years).
For reference, here is a selection of new car prices!
That seems about right given 20% VAT and a 1:1 pound/dollar rateI can only find the F208 mentioned above new, and they cost £5399 here. The F328Be cost £15995.
Different tastes and needs.Now that me and my room got to know each other a litlle better I would choose none of the two.
What I'm trying to say is that our friend has the opportunity to have "big sound".
What is "big sound" now...
Can't really describe it,it's about perception and it has to do with the room and the ability of the speakers to fill it properly.
Once you hear it you know it.
It doesn't come cheap though,I know so by exhausting every possible solution before turning to pros.
I wouldn't think of bad or good or right or wrong.Different tastes and needs.
You have a point, if you haven't experienced something (really good), then you only compare it to the mediocre you've tried and are used to. Having said that, I don't think the speakers suggested in this thread are mediocre, on the contrary, but the principle itself. Also applies in general and not just HiFi.
An extreme, if we are talking large areas. A large indoor arena, then of course all the speakers suggested in this thread would only be a fart in the space (or rather a fart in that arena). Then a substantial BIG PA speakers/system are needed.So yes, the size of the listening room and absolute listening distance has a great importance for the choice of speakers, sound solution.
Examples of large PA speakers, PA solution:
Line array - Wikipedia
en.wikipedia.org
Costs quite a lot, of course:
New and Used V-Dosc Line Array System for sale
V-DOSC - Large Format Line Source V-DOSC® has revolutionized the loudspeaker industry with its outstanding sonic results for large format live sound reinforcement applications. L-ACOUSTICS® V-DOSC® is the first full frequency line source array based on the principles of Wavefront Sculpture...gearsource.com
BUT it can, perhaps, be a sensible solution for home HiFi as well. You will most likely then have to build them yourself as there are few line speakers for home HiFi for sale, as far as I know anyway. Advantage of line speakers reduce or eliminate floor and ceiling reflections. Reduces the need to fix the acoustics in the listening room.
Line speakers requires some EQ. You or anyone who is interested can read about that in ppataki's DIY thread:
(attached pictures are from that thread)
Murphy's Corner Line Array project
Another update: the 'sandwich' panels are done! As you can see in the below pictures, Green Glue has been applied between the panels (2x12mm birch plywood) There are some panels missing, they will be done a bit later The next phase will be to put together the back of the speaker, paint it (with...audiosciencereview.com
What speakers do you use yourself?
Maybe I should elaborate. Yes most people, even those who are not interested in HiFi, would dislike speakers with very uneven FR, and or hm an old crappy car stereo where the volume is turned up really high and it starts to distort so that your ears hurt after a few seconds. There is something that most people probably consider to be bad/wrong.Okay, it was extreme, but still.I wouldn't think of bad or good or right or wrong.
I'm sure there's a right way to approach it that most people would like.
What I do know is that even though there is a consensus in what most people like it's personal enough to dig a little more avoiding any possible bias (established ways,what you think you like,what other people think,etc).
I now own biggish 3 ways (about 160 lit),semi-actives.Better think of it as an installation really.
Edit:
That's the curve I try these days (before EQ to shave low end a little)
Seems a little bass-heavy but with the classical material I listen to sounds ok.
I knew what Murphy's law was, but I didn't know this, from that Wikipedia link. Interesting:
I agree, I have auditioned by listening in stores and demoroom a number of “ perfect “ measuring speakers like KEF Blade 2, R11, R5, Monitor audio 500 silver g2 , and I would not buy any of them . Kind of flat and unsatisfying boring sound . And I am a guy that hate Klipsch sound, my 25 years old Audio Physic Virgo 2 also measure kind of perfect but sound much nicer to me… You have to listen.Don't even consider for a second spending $3850 on a pair of speakers without listening to them first. Find a dealer, drive to a dealer, or buy/borrow a pair on appro.
If you don't like the boost in the treble that the Klipsch can have, plus if you you like the boost, that extra umph in the bass, I understand if you like them... . And I am a guy that hate Klipsch sound, my 25 years old Audio Physic Virgo 2 also measure kind of perfect but sound much nicer to me… You have to listen.
