Distortion shouldn't be a problem unless it's over-driven, so most important factors are probably power handling and X-max.
It's even more important that the Thiele-Small parameters "match" the cabinet volume & port dimensions.
Or if you want to replicate the original sound, maybe you can find one that best-matches the original.
Of course the the speaker was designed before Thiele & Small published their work, and before computers ware commonly available for analysis so the Thiele-Small parameters were unknown at the time and the cabinet would have been optimized-tuned to the driver experimentally. Maybe someone has measured it? But you can probably do better than the original design (with the bass response tuning).
