Audionaut
but also no real problem because in that case you can connect two additional Bluetooth modules that meet your requirementsAnd unfortunately he also had to tell me that the JAB5 does not support it.
That's a real pity.![]()
Actually I found solution,my Samsung s22 ultra has this dual audio optionThat's true (via I2S then), but I would then have to connect the two speakers with a cable. That makes the Bluetooth option a bit absurd.
https://www.tinysineaudio.com/products/4-x-50w-bluetooth-dsp-amplifier-board-tsa7804bapt-xI just got off the phone with a very friendly employee from boomaudio.de. He also took the opportunity to tell me the name of the Bluetooth-standard for what I'm looking for: TWS - True Wireless Stereo.
Best way is to avoid unnecessary conversion,currently you have dac>adc>dac>amp setup,too much conversion,best way is to transfer digital signal straight to jab5 with i2s protocol,this board has usb to i2s pass-through,so you wont need to use your own dac:Can someone suggest the best possible way
But I also use optical and analog.
You will need 6 pin cable,just connect it to i2s input on jab5,in sigma studio 5,6 inputs are i2s,make sure jab5 is in slave mode and converter is set to master mode.How is al lthis connected and how do I select the input?
You can add dc block module at the beggining,just incase,it will block dc on input.created a design that I hope will work.
I think the TinySine Board are able to use TWSAnd unfortunately he also had to tell me that the JAB5 does not support it.
Hi Roman,You can add dc block module at the beggining,just incase,it will block dc on input.
