Follow up from SVS:
Thanks for reaching out to SVS!
At one time all SVS subwoofers had a high pass on the line level outputs. Based on almost two decades of customer feedback, this feature was almost never used, and also requires some DSP which is something audiophiles eschewed. So it was dropped as a feature in our subwoofers and we have no plans to reintroduce it.
The best way to integrate a subwoofer into a 2 channel system is to run the speakers on full-range and then low pass the subwoofer at the natural roll-off of the speakers. If the speakers are sealed use a 12 dB/octave slope on the LPF and if they are ported use a 24 dB/octave slope.
Adding a HPF to the speakers will create integration problems with the subwoofer, because the speaker will initially track the slope of the HPF, and then it will start to roll-off naturally and the resulting slopes will be additive. This will create phase asymmetry with the subwoofer on the low pass side.
If you truly need to high pass the speakers, then I recommend looking at the passive line level Harrison Labs FMOD or a mini-DSP 2x4 HD.
Thanks and if you have any other questions, please don't hesitate to ask.
