So why don't they like opamps? What's the difference between the two? Why would an engineer decide to use one design over the other? What are the use cases and the pros and cons of each?
An audio device manufacturer wouldn't be the one creating an OpAmp it seems, in the same way they wouldn't be creating the DAC chip itself in the same way.
It's like the same way why there are only just a handful of battery OEMs. You can't actually make your own battery that could ever compete on the market, simply because battery tech requires billions in R&D. Again.. likewise when Dell makes a computer, they aren't making any parts beyond housing. Or when you see a keyboard from Dell, or Corsair using mechanical switches. They're not actually making the keyboard themselves and the switch mechanism.
All of these devices in 99% of cases are built with companies that specialize in the creation in each of the parts. Again, you're never EVER going to make your own GPU that would resemble anything capable of competing with an AMD variant let alone an nVidia variant.
So what this is basically evidence of, is nearly all the advanced electronics we use, are either off-the-shelf parts that can be ordered (or if you're a preferred customer ordering parts in the millions of quantity, then you can actually have coffee with the OEM about designing a custom part of your own design perhaps, and they will work with perhaps realizing your ambitions).
This basically is beneath audiophiles (audiophools). Because using plebeian off-the-shelf parts is beneath them. It's mainstream garbage that barely executes on utility for those who simply have to have something barely functioning. They see any company doing work as much as possible in-house as virtuously more worthy of their attention and hard earned money, simply from the fact they're willing to do most of the design and (in theory) that allows the company the freedom to create products and parts that function better than the amalgamation of parts used in products from companies that use OPAMPS and DAC chips from AKM or ESS for example. It's why you see things like R2R still hold sway (R2R was a way of doing things before globlization made specilization of parts creation the logically efficient thing to do when trying to serve 7 billion people on the planet. Building R2R for every single DAC ever made in the presence of AKM and ESS is just idiocy, or just vanity seeking at this point in the same way a mechanical watch is, except mechanical watches don't try to lie and say they perform better than quartz, while audioidiotphiles think they can take the win on all fronts, aesthetics, performance, without something giving way).
The reason OpAmps are a nightmare for audiophools is because they're now good enough to beat custom designs that used to actually result in devices that would perform better than a DAC or AMP or whatever, built with off-the-shelf parts. Now those off the shelf DAC chips for example; plow right through all R2R implementations to a degree where R2R simply looks like vinyl, where there is NO chance by physics they can outperform things like dynamic range of digital.
So the nightmare, is the butthurt all their desires are for a technology that is getting slapped by approaches to design that are considered inferior in virtue of the less work required, that still produces measurably better performance on nearly all fronts.
And THAT is why - I hope as a layman - I think he said OpAmps are an audiophiles nightmare.
