Did you happen to measure the device with preamp mode turned on? Wondering if there's much of a change in the measurements in that mode compared to fixed output.Coming with the Sanskrit 10th AK4493 Edition, there is also an upcoming SMSL M300 MkII. It seems that there was a measurement requirement for M300 before the forum?
j to tak ako má byť ! rozdiel v každom ohľade od cinch.Ahoj.
¿Salidas XLR a SMSL M300 MkII sú v rovnováhe alebo sú sólo pre dekoráciu alebo pohodlie?
Muchas gracias.
Saludos.
I think I've answered my own question. I still get a different progression of harmonics with third still being higher than the second but I'm now getting SINAD results in line with WolfX-700's. This DAC has a setting called, "High Sound", that isn't very descriptive. I think that this setting puts the AKM 4497 into high power mode and in that mode we get dynamic range and distortion in line with manufacturer specs and Wolf's measurements. Here's the graph with the M300 MKII in High Sound mode.I was playing around with my new Cosmos ADC and did some measurements of my SMSL M300 MKII.
Have you more pictures from inside ?[QUOTE = "pdm555, príspevok: 569546, člen: 22149"] Otvoril niekto tento DAC? Chcel by som vedieť, aké zosilňovače sa používajú na analógových výstupoch. [/ QUOTE]
hello friends! Good question ... so I opened it and took a picture. they are: OPAMP Texas Instruments L4562 MA
Hi, I have already moved the device and currently switched to the SMSL SU9 Pro (the jump in performance is amazing) but I have only taken 2 photos of the SMSL M300MK2.Have you more pictures from inside ?
Thanks
Thank you for asking!zajogungster Thanks for your time. hobe your satisfied with your SU 9 PRO
