Standing in the rain
- Joined
- Jan 22, 2019
- Messages
- 87
- Likes
- 65
What is the best filter to use for CD on this dac ?
Personally I don't hear any difference between the PCM filtersWhat is the best filter to use for CD on this dac ?
Can't speak to the bluetooth feature because I haven't used it once. But as for the sound colors, I personally don't hear a difference (and won't even try pretending otherwise )Any feedback on how the different "sound color" modes affect the sound?
Also can anyone comment on how the volume on bluetooth mode compares to the rest of the inputs?
Thanks!
Yes I’m trying to figure this out as well. What are they doing exactly? @SMSL-Mandy explained that they come as part of the AKM chip, but the data sheet is way over my head.Any feedback on how the different "sound color" modes affect the sound?!
I'm under the impression that crosstalk is not an issue with current DACs so it's not published/tested any longer (guesstimate: ~-130dB).Not that it matters but I can't seem to find a crosstalk measurement anywhere for this. Would someone be able to direct me to one?
M300 is marginally better but for SE, you might as well just settle for the E30 (imo).Also, I don't require balanced outputs and I'm fine with RCA. How does the M300 MKII compare to the E30 aside from the balanced vs RCA? Again the M300 MKII seems better, but it is also $70 more.
does anyone know what the max Vrms output is at max level on XLR. i'm trying to figure out if this puts out close to the 6.8 V that the M500 does.
Maybe bypass some kind of output stage?There is nothing special going on in the pure Dac mode other than fixing the volume, right?
