Witterings
- Joined
- Feb 19, 2022
- Messages
- 319
- Likes
- 135
I'm guessing if I'm using and Echo Dot plugged into an Amp via the 3.5mm jack there must be a DAC in the Dot that's doing the conversion and will be the weak point / limitation to the overall quality?
If as an alternative I use a Chromecast Audi with Optical out straight into the Amp I'm probably going to get a better quality DAC in the Amp than the Echo so therefore a higher quality sound ... is that correct? .... I then have a decision as to whether I believe an external DAC could improve the sound in comparison the the Amp's onboard one?
Lastly is there any advantage of using a WiiM Mini Streamer instead of the CCA ... I believe one of the liiting factors of the CCA is a max 320 bitrate which is lower than an Echo Dot ...... how much effect may that have?
