Wilson Audio TuneTot Review (high-end bookshelf speaker)
Rate this speaker:
    Votes: 364 58.8%
    Votes: 186 30.0%
    Votes: 44 7.1%
    Votes: 25 4.0%
Mart68
England
Many of the pre management-change Sonus Fabers were actually very good speakers for the period they were sold in (I made the mistake of form over function too until I looked inside one or two and actually spent time listening to them, upon which a few models won my heart). Not sure about the smaller modern models, as they seem to have gone awry and become hf sparklers as some other models catering 'for the more mature male? listener with old-man's hearing ' now also do.
I wasn't saying there was anything wrong with their sound, just that they put extra effort into the appearance as a way of distinguishing themselves from a dozen other brands.
kokakolia
Every brand does that except for Dynaudio which makes their speakers look uglier by design. They love to have 20 exposed screws on the front for example.
Vacceo
Dynaudio, like Dali, seem to share designer with Ikea. They are not ugly, they´re super functionalist.
FeddyLost
Plain and simple as grandfathers did, I'd say.
Super functionalist are The ones with zero diffraction enclosure, for example.
Dynaudio also use directivity control in newer models, but much more expensive.
I kind of like the screws, hahaha, maybe because I used to build my own speakers…..
dfreshness91
This is a review and detailed measurements of the Wilson Audio TuneTot stand-mount/bookshelf speaker. It is on kind loan from a member and costs around US $10,000 (varies due to color).
I am not a fan of the way the front looks without the grill. The sides though sport probably the best finish I have seen on a speaker with deep gloss and polish. Speaker is also incredibly heavy and stiff for its size (29 pounds or 13 Kg). Drivers are custom versions of Scan-speak Revelator.
There is a down title rectangular port in the back:
I put in the very well designed dense foam plug that fits the port exceptionally well. In testing it really plugged the port unlike foam ones which half of the time feel like they are not doing anything.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the center of the tweeter (aligned by eye). The grill was not used. It is getting colder with the measurement room temp at 14 degrees C. Accuracy is better than 1% for almost entire audio spectrum indicating a well designed speaker.
Wilson Audio TuneTot Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
On-axis response clearly doesn't look even. There is a massive peak around 115 Hz then real messiness around or near the crossover region. Directivity is lost around 3 kHz as well. Exploring the impact of the port, we see why that peak is there in bass:
Very strange to see the port tuned to boost the response at such a high frequency rather than extending it lower.
Oddly again, the sum of the early reflections is better behaved than on-axis:
This causes the predicted in-room response to be much smoother than you would expect from looking at our original spin graph:
As we could already guess, beamwidth is not uniform indicating room dependency:
Radiation pattern is wider than usual though which should give a more spacious impression than a point source around the speaker:
Vertically you lose some margin due to slanted baffle so best to not go above tweeter axis:
Distortion is kept very low at 86 dBSPL but I could hear a resonance during 96 dPSPL:
To rule out the Klippel stand from contributing to this, I literally held the speaker above it as the sweep ran and I could hear the resonance at a specific frequency. Strangely the frequency response drops there so the resonance must be out of phase. Here is the near-field response:
I only see minor variations of the woofer response so hard to say if the above is really the problem. I did like the fact that the port/cabinet resonances are kept low. Woofer response does step up some though and is reflected in the frequency response (between 700 Hz and 1 kHz). Is this due to too little baffle compensation?
Impedance is above average which should make it easier on the amplifier:
There is a sign of that resonance at 2.6 kHz that we saw in the distortion measurements.
Waterfall response shows a number of resonances corresponding with peaks in response:
For fans of timing analysis, here are the impulse and step response (yes, phase is inverted -- I need to fix this):
Wilson TuneTot Listening Tests and Equalization
Listening test system was a custom, silent Roon Server/Player ($2,000) connected to Matrix X-Sabre MQA DAC ($2,000), and Mark Levinson Reference Amplifier ($20,000, 400 watts/channel) playing custom tracks developed for testing headphones and speakers.
I started playing with the port open. With my female vocal tracks, the extra bass was not all that bad and compensated partially the slight brightness of the speaker. But when I played content with much bass content, it became overwhelming. I plugged the port but then there was not much bass to satisfy. So I removed the plug and deployed a few filters:
The first dip should be self-explanatory to remove the extra bass boost. Doing this from anechoic measurements is tricky though as in-room response likely looks very different. So I adjusted this by ear and admittedly on some tracks I wanted slightly more of it. With this filter in place the bass was now tighter and overall sound of the speaker more open. Per above though, there was some brightness that gave me hell to deal with. Likely due to bad directivity and mismatch of on and off-axis, using an electronic filter that impacts both is very challenging.
I eventually gave up on optimizing using on-axis response and roughly used the Predicted In-Room Response (by eye) to develop the two other mild filters. I performed a number of blind tests and overall I preferred the equalized response. There is a caveat that you need to know what good and clean bass is and the overall proper tonality. Otherwise, the "showroom sound" aspect of this speaker can be seductive making you want to listen to boosted bass and slightly elevated highs.
For comparison, I switched back and forth a dozen times with Revel M106 speaker ($2,000). The Revel had a smaller halo and sounded more focused than the TuneTot. It had none of the brilliance of the Tunetot but his was a dual edged sword in that the TuneTot constantly gave the impression of a more detailed, and "audiophile" high frequency notes that were very nicely delineated. TuneTot also had deeper and cleaner bass response than the M106. Overall, I preferred the TuneTot over Revel.
I briefly compared the TuneTot to my Revel Salon 2 ($23,000). Revel did not have the exaggerated spatial qualities of the high frequencies that TuneTot had but overall presented a much more balanced tonality and of course, much more bass impact. Its midrange was so smooth and nice. Still, I was amazed how the TuneTot did not sound small compared to it whereas the M106 did.
Sub-bass response on TuneTot was better than I expect from a small speaker. Push it though and the woofer starts to make bad sounds as they all do in this size factor and playback levels.
There is no question that there are some clear objective/engineering errors in the design of Wilson TuneTot. The port is tuned too high and the on-axis/directivity response is poor. What is strange though that the impact of these on the fidelity of the speaker is not at all this obvious. Either I am influenced by the showroom sound as much as the next guy or getting off-axis to be right in my rather reflective room overcomes issues in on-axis response. It is also possible that all the money that has gone to building such an extremely dense speaker and keeping distortion low is paying benefit here. One wonders how much better these would sound if they had had preserved all of this and at the same time didn't have the design errors.
If I were to just goy by the measurements, the Tunetot would not get good marks. But I have promised you all that I won't lie about what I hear no matter how much of a conflict this provides. To that end, I am going to recommend the Wilson TuneTot with equalization (cost not considered).
Even after reading this review, i demoed and bought a pair after trying BandW 805d3 dynaudio heritage specials and spendors. Akudoris. Etc. the tunetots with some naim amplification sound fantastic. Never has so much music been played in my house. I do have an rel sub To go with them. Those who criticize the price and say just scanspeak woofers etc dont understand the further engineering and craftsmanship that goes into these. they are musical engaging and real.
Pearljam5000
But are they accurate? :)
Purité Audio
Industry Insider
Barrowmaster
London
Difficult to know what to say, you could have had so much more for so much less.
dfreshness91
My music sounds real.
ive listened to a lot of speakers. Formy setup they are perfect. What would you recommend. nothing had the tone depth or image that i listened to. I have revel m22s bowers 705 s2
Mr. Widget
SF Bay Area
I'll confess I only quickly reviewed Amir's first post on this thread and very little in-between, but I think we get hung up on "accuracy".
In an ideal world every speaker would be ruler flat or slightly tilted downward for those systems with no ability to introduce a room curve, but in my opinion we humans are able to internally "auto correct" for nonlinearities in frequency response better than any of the other nonlinearities that sound systems create. After a few minutes of listening to a system we "normalize it" and once again a violin sounds like a violin and a snare, a snare.
I have never heard Wilson TuneTots. My bias is that I really like some Wilson speakers and really do not care for others... and I don't appreciate the brand's aesthetics.
If @dfreshness91 finds these speakers to sound "real" in his room, I can't argue with that. If I was there I might agree or not, but unless I have the opportunity to hear his system in his room, I will go along with his assessment and try to leave my measurement biases and brand snobbishness biases at the door.
heflys20
With substantially cheaper, (arguably) benchmark speakers on the market (like the recently measured kh150) with built in room correction; it amazes me that anyone would pay 10k for these passive speakers. True, measurements aren't everything...But the science supports something like the KH 150 sounding substantially better. I'm speaking from my perspective, no judgement. Lol.
Mr. Widget
SF Bay Area
If I were to just go by the measurements, the Tunetot would not get good marks. But I have promised you all that I won't lie about what I hear no matter how much of a conflict this provides. To that end, I am going to recommend the Wilson TuneTot with equalization (cost not considered).
I applaud your keeping an open mind during the audition of these speakers. Many of us, and I have been guilty of this too, become biased by what we have measured.
I think most of us here would come to the same conclusion... but I am only piping up here to remind myself and anyone who wants to listen, that we owe it to ourselves to try to keep an open mind. Measure and test to be sure, but at the end of the day there is no substitute for unbiased listening. Double blind when possible.
Regarding the cost of these speakers, I generally ignore price until I find myself on the wrong end of the cash register. ;)
pablolie
bay area, ca
Wilson speakers have a clear signature -I have listened to a few of their models-, and their intended audience clearly buys it [literally]. Just like several British speakers do. The US audiophile press pitches Wilson speakers just like the British press pitches their own. I respect personal preference - but measurements are what they are, and if your preferences are for certain signatures, it's ok. If a speaker that strives for great linearity (a perfectly measuring speaker may never exist for many reasons) isn't for you, hey great for you - and ignore discussions that disagree with that sentiment if you're truly happy.
Gremlins
With that money, i would have gone to Italian Diapason Adamantes V speakers .. real craftmanship
voodooless
Netherlands
Why would you do that to yourself? 6.5” driver crossed at 4.6 kHz? No crossover on the woofer? Why does it look like a Seas coaxial? This thing is all kinds of strange.
Gremlins
Listen to it, witness how it is made, abstract price , and come back with an opinion
voodooless
Netherlands
I’m sure it will sound very different. That is the point with so called high-end stuff. You have to stick out. Best way of doing that is with flawed designs.
