AnalogIsTheWay
- Joined
- Jul 7, 2025
- Messages
- 12
- Likes
- 11
I figured a positive comment about "Actually hearing a speaker before judging it" would enflame this place.
There's a premise that is lost here, and I dont know whose fault that it, but it really should be identified before people throw measurements and science out.
Measurement are used as a baseline, and a control. When someone builds a $70K or $100K pair of speakers, they aren't going to use the same baseline as a pair of 1K speakers.
They're going to make some assumptions:
1. People that buy these are going to have some of the best source of amplification on the market
2. People that buy these are going to have them professionally set up and maintained.
3. Our customers will have dedicated rooms, built with the speaker as the central focal point.
4. They will likely have very large budgets for source components and room treatments.
Why, why, would a company that is catering to that listener want to create "measurements" that cater to use cases that their customers dont care about?
I dont give a shit if the 'off axis' number on Alexia's arent perfect with a yamaha amp.
I dont care if my speakers can sit on castor wheels and be moved around my living room, anywhere I want to make room for guests, and still have the same performance.
I dont care if my speakers need an inefficient level of power, because Wilson and Dag amps are built and tested with eachother. Wilson makes a speaker that is intended to sound sublime with a Dagostino amp, perhaps at the expense of sounding as good with a Cambrdige amp.
Theres something called: System-Level Optimization or Interoperability Margin. It's when devices are designed with a bias, intentionally, because the bias will provide them a performance boost when used "as expected". Or optimizing for an unrestricted, low-impedance system load.
Wilson Audio explicitly designs their speakers under the assumption that the end-user will be pairing them with exceptional, high-current, low-impedance power amplifiers
Because they assume the amplifier is "exceptional," Wilson does not compromise their driver selection or crossover complexity to make the speaker easy to drive
All the scientists on here should surely understand that concept when measuring devices.
