I couldn't agree more. What is that thing even for?A pre-baked cheap crossover is pretty funny, tho.
I don't wanna know actually.I couldn't agree more. What is that thing even for?
I doubt anyone argues about using good components, or polypropylene caps for example. But the industrial-rated polypropylene caps I use (when necessary) are under 10 bucks, and DigiKey and Mouser sell them. They have actual specifications, too. Few "audiophile" caps have anything like specifications.Lets not make fun of this to soon. High quality cross over caps are important for two reasons.
First is lifespan and drift free performance as they age. Good caps stay in spec longer maintaining cross over performance over time.
Second is precision specifications. Quality caps have a higher specification tolerance. Perhaps 5% instead of 10% or 20%. Higher tolerance caps match specifications between the speakers better and therefore provide a more accurate crossover frequency between the speakers. This will help prevent image drift at the cross over region.
So I would say it does matter. Can you hear the difference. I'm not sure. Perhaps in cases of a bad mismatch. Never the less you want the speakers to match as close as possible. Cheers.
Noobs read articles on crossovers and think that's how you do it.I couldn't agree more. What is that thing even for?
Are you mad? The fuses are not imprinted with the word "Audiophile" so apart from being terrible, they will work either way round, which is stupid, as it means you get double the number of electrons on AC. Kaboom!As long as the fuse is installed the right direction.
Yes, and that fuse only cost a buck or two. It must sound terrible.Are you mad? The fuses are not imprinted with the word "Audiophile" so apart from being terrible, they will work either way round, which is stupid, as it means you get double the number of electrons on AC. Kaboom!
I'd still bet the PCB works as a high pass-filter, so long as the fuses are removed.
You'll note that copper in the coil is not the requisite 115% pure copper, nor a mono-crystal, nor enameled with the extracts of an angel's glands.Yes, and that fuse only cost a buck or two. It must sound terrible.
Many people here can't hear the stark difference a good power cord makes. It's sad, really.You'll not that copper in the coil is not the requisite 115% pure copper, nor a mono -crystal, nor enameled with the extracts of an angel's glands.
I'll stop now, as it's lunch time. I have an audiophile-grade £1000 quiche in the oven, and I'm off to eat it in front of poor people who all have cloth ears.
NO.Will upgrading the capacitor, improve the sound on this crossover?
Dayton Audio 2k-HPF-4 High Pass Speaker Crossover 2,000 Hz 12 dB/Octave View attachment 557208
A lot of Dunning Kruger effect in DIY audio especially car audioI couldn't agree more. What is that thing even for?
The internet just adds fuel to the fire by having lots of filter calculators available. And if drivers were perfectly resistive 8 ohms (4 ohms etc), that would be great!A lot of Dunning Kruger effect in DIY audio especially car audiojust throw in drivers in home made boxes..
Gotta be oxygen-free beryllium screws for the best sound.Those labelled mounting holes are begging for a discussion of what type of hardware to use.
5% tolerance is lower than 10% (semantics)Lets not make fun of this to soon. High quality cross over caps are important for two reasons.
