will NC252MP amplifier module drive my speakers?
DKT88
South Korea
I'm wondering if a Hypex 252MP 250W per channel amp will drive my speakers (Thiel 2.2) to modest listening levels at about 10 feet. I suspect the answer is yes but I have some uncertainty and can't demo it. The speakers are 86db sensitivity and are nominally 4 ohm with a minimum of 3 ohms. Is there anything about the class D amp performance specifications that I'm missing?
RayDunzl
Central Scrutinizer
Riverview FL
Is the rated power appropriate?
Yes. Should be more than enough for "modest" levels.
andreasmaaan
If I make a couple of conservative assumptions about your speakers and room:
  • speakers require around 1W to reach 82dB/1m (based on 2.83V/86dB/3Ohm)
  • critical distance in your room is around 5 feet (in most domestic rooms it is less)
You will achieve 83dB RMS (my definition of “moderate”, based on the recommended level for mixing/mastering) at the listening position with about 1.5W of input power. Assuming a 20dB crest factor (ie for more dynamic recordings), that would mean 150W for peaks of 103dB. You’d then want some headroom, say double or 4x the power required for 103dB peaks, which would get you to wanting about 300W or 600W (although the speakers may not be capable of handling this much power).
Also note that I’ve made quite conservative assumptions here, basing the numbers on a higher than typical critical distance and the lowest impedance of the speakers.
Ron Texas
Typically, an NC252 requires 2.35V to drive it to full power. Few unbalanced DAC's have more than 2.1V maximum output.
HammerSandwich
You will achieve 83dB RMS (my definition of “moderate”, based on the recommended level for mixing/mastering) at the listening position with about 1.5W of input power. Assuming a 20dB crest factor (ie for more dynamic recordings), that would mean 30W for peaks of 103dB.
How does +20dB correspond to 20x power output?
RayDunzl
Central Scrutinizer
Riverview FL
Opinion:
I find my C-weighted long term Leq SPL value for modest listening to be in the low to mid 70s range...
Dire Straits - Making Movies
March Audio
Albany Western Australia
Hi
As the other members have said the 252 will drive your speakers to fairly high level.
If you have any specific questions please don't hesitate to ask.
Ron Texas
That does depend on the load impedance. 4 Ohms it's 2 volts.
I got the 2.35 V spec from Nord, and can't remember if they said 8 ohms, but your statement makes sense.
DKT88
DKT88
South Korea
Thanks to all for the help. I was thinking about the problem narrowly as steady state output from an amp and had missed the other factors including input V , dynamic response, headroom and what "modest" means in terms of SPL.
Trdat
Yerevan "Sydney Born"
I'm trying to research more about how a preamp(DAC)will effectively drive a Poweramp and I stumbled here it seems I'm getting closer. In my case I need to power my NC252 and have the minidspDAC8 with only 2Vrms. Is the Vrms the only thing we are looking at in a DAC when it comes to choosing a DAC preamp? And if it's only 2 V how much am I loosing out on and what can I do to get to full power on the NC252?
boXem
Europe
This 2.3V is linked to an old erroneous spec from Hypex. For the NC252MP, 1.82V are enough to get it clipping into 8 ohms. So your minidsp DAC8 is perfectly fine.
Trdat
Thanks. And what specification am i looking for on the power amp for this?
Trdat
Hey Boxem,
I have been looking at the specifications page but can't quite figure out which exact column I am looking at? Could you direct me to the exact specification?
In another amplifier I got Maximum gain (0.775V) 42.4V. Is this something different or what im looking for?
Matias
São Paulo, Brazil
Hey Boxem,
This part of the datasheet shows that for full power (250W) at 4 ohms it requires 1.66 V RMS, which is below the standard 2 V RMS for RCA or 4 V RMS for XLRs that sources usually have.
HammerSandwich
You need the voltage gain from the table and the equations under "input sensitivity." Hypex shows you exactly how to calculate input levels for the rated 250W at 4Ω.
The numerator of the first equation - sqrt(Wrms * Rohms) - converts the amp's output in watts to Vrms. The denominator then uses the gain to scale that to input level, also in Vrms. If you want to get lazy, 26dB is a voltage factor of 20x, so you can simply assume the denominator = 20. That will be close, unless you gain-mod the amp.
TLDR? Because the 4Ω output is less than double the 8Ω, the amp needs more input to clip 150W at 8Ω: 1.82Vrms. Boxem already mentioned this in post 14.
Trdat
So if 1.66 Vrms is needed to power the amp to its maximum than what is the 2.34 V peak? Is that the peaks it can reach?
