- Joined
- Jan 5, 2024
- Messages
- 72
- Likes
- 27
- Thread Starter
- #21
Finally got around to measuring my pre-amp output voltage with a multimeter. Using a 100hz tone (as generated in the screenshot above), I varied the volume and took several measurements. I found the following:
- Volume 0db : 4V
- Volume -5db : 2.2V
- Volume -10db : 1.2V
- Volume -20db : 0.5V
With any volume below this (the lowest possible setting on my Yamaha is -69.5db), the measurements were too volatile. For example, when I set the volume to -30db, the multimeter readings jumped around between 0.04V and 1.5V. I am guessing this is likely due to the lack of precision of my instrument? (I used the Etekcity multimeter recommended above.)
So I guess this means that the pre-out voltage does in fact go up to 4V, which is good to know! However, what concerns me now is that the voltage seems to jump a huge amount between -10db and 0db (1.2v and 4V). Does this mean that I will hear huge jumps in SPL when I try to use this pre-out with a power amp such as those that require 2V in for max power? In other words, will minute volume adjustments not be possible at louder listening levels? Hope this question makes sense.
- Volume 0db : 4V
