CaptainBeyond
- Joined
- Aug 21, 2022
- Messages
- 24
- Likes
- 4
The audio system I’m currently listening the music, watching movies etc. from are the JBL L82 speakers (stereo set) plugged to Yamaha A-S801 amp outputting signal via optical cable from my desktop computer directly to the amp’s dac. Im very happy with this system but with broad eq fixing some stuff ever since I solved initial problems with it that I described here somewhere around 2021-22.
As I recently move from place to place a lot I find it harder and harder to fit this gear to the new apartments since JBLs are lets say pretty boxy design as for an 8inch woofer bookshelf, not to mention the amp itself.
Also, recently by an accident found in the internet the replacement new jbl manufactured grille for the speakers to cost 120 euros (!!!) considering its just a quadrex foam with some thin plastic around it that manufacturing costs are (at most extreme case) worth like 20 euros. Not to mention these speaker stands cost 250 euros which are in reality at extreme worth 60-70 euros in my opinions (have them too) which is hillarious.
Also in a recent months I had an opportunity to try lets call it higher end dac on my system (about 800$ price range), which changed completely, audibly NOTHING regarding the sound quality over the cheap lower end built in amp dac. Later on some audophiles argumented in other place that its because the rest of the system (amp to be exact) is lower quality (really? Considering all of the gear has a flat frequency response if I understand correctly? – maybe excluding the speakers, but they are not coloring that drastically judging by the measurements IMO).
Remembering the realities of modern audio gear marketing and audiophile b(ia)s I learned here came to thoughts how much overall I overpaid for the speakers (which themselves are very nice, I like them a lot, they have very unique dynamics I never found before with any other speakers I tried, that fit so right for the music I like, not to mention these retro looks, but are these dynamics and looks are worth lets say 1,5k dollars?
If the speakers were up to 1k dollars range msrp, I wouldnt have such doubts at this point
I also recently started playing around with audio production, or let say, just guitar home tracking for further processing by the professionals.
To sum it up all together I started wondering if I could get back some of the funds, I maybe, lets say it straightforward, wasted on the speakers, since they still hold a value being pretty new and in excellent shape, and still get the same quality of the sound and music I have right now, having more versatile (in terms of fitting to the room), smaller speaker with the same woofer size (8 inch) , same dynamics, same music details that I could additionally also plug via xlr to the audio interface Im recording on with? For less than I spent on the JBL L82. I mean - to switch from a stereo speakers powered by the integrated amp I have now to the fully active speakers (near/mid field) and then eventually add a dac with xlr output which could be handy for me in such configuration for a recreational listening?
Keeping in mind to not fall from the audiophile rabbit hole to the measurements and tech hype for the sake of the tech or some states of the art designs – not the real audible profit - rabbit hole. Just pure price-quality ratio economics, not overpaying for non audible stuff etc.
The models I considered so far, are (used):
JBL 308P MKII
Yamaha HS-8
KRK Rokit RP8 G5
With strong emphasis on JBL’s. And was thinking about something like the cheapest Topping dac model with xlr outs, D70 or something (used too).
My questions are:
What I would eventually loose switching from previous system to such configuration? Which specs play the crucial role here and which I should pay the most attention for? Remembering the studio monitors by their principle have flat frequency response and are made for the music production that is further listened also on a ‘high end audiophile gear’? Will such swap be a degradation? What are the pros and cons of it?
Will really budget 350$ active studio monitors wont be indistinguishable in a blind test with a higher end „audiophile” 3k $ system?
Will switching from 120 watts per channel in 8 ohm (yamaha as801) into 80watts per channel and 50watts on woofer (in JBL 308P MKII) will make me loose sound quality on a louder volume gain? Near - mid field room listener here.
Maybe I should also consider keeping the JBL-s with lets name it – collector reasons and they will gain value over longer time for collectioners like for example the guitars do? Once they will get deadstock. But I bet its gonna take a while.
And finally - If you were me with such doubts, simply would you keep my system? Or take some of the actives Im considering and sell L82's? If so, which ones from these three and why?
Thank you very much for responses and best wishes!
JBL 308P MKII
Yamaha HS-8
KRK Rokit RP8 G5
My questions are:
