That combination is over $400 and the amp is a bit weaker than the Wiim. Also, the $400 price is not official and the actual price is likely to be lower. But yes, if the price does end up being $400 then you can get roughly equivalent performance for the price out of two separate boxes.For example, the one I use - SMSL DL200 and Douk Audio A5.
Excuse me? What is over $400?That combination is over $400 and the amp is a bit weaker than the Wiim. Also, the $400 price is not official and the actual price is likely to be lower. But yes, if the price does end up being $400 then you can get roughly equivalent performance for the price out of two separate boxes.
Douk A5 is $100 and SMSL DL200 is under $200; combination is under $300.That combination is over $400 and the amp is a bit weaker than the Wiim. Also, the $400 price is not official and the actual price is likely to be lower. But yes, if the price does end up being $400 then you can get roughly equivalent performance for the price out of two separate boxes.
Ah pardon me. Confused the Douk Audio A5 with the 3e Audio A5 there.Excuse me? What is over $400?
I see no reason to mistrust the manufacturer's measurements posted on the user's manual of the product. Sure, if this WiiM amp has about 10DB more SINAD compared to the Douk and this is what a person values more, everyone can make his own purchasing decision. I bought my combo for less than $250, the DAC has a headphone amp, and the amp has a high-pass filter. These two features, combined with the (more importantly) $150 difference make my choice a very easy one. The last thing I miss is 10 extra db SINAD. But absolutely, to each their own.Ah pardon me. Confused the Douk Audio A5 with the 3e Audio A5 there.
So your combo is around $300, but that Douk has not been measured that I'm aware of and the numbers on the website are pretty suspect. Pretty sure it does not match the performance of the Vibelink here.
It's not merely about SINAD. It's about lack of PFFB (and therefore load dependency) and power figures listed without any noted impedance or distortion, or whether the figure is continuous or transitory. I'm quite certain the power figures in an ASR review would not resemble what they are listing.I see no reason to mistrust the manufacturer's measurements posted on the user's manual of the product. Sure, if this WiiM amp has about 10DB more SINAD compared to the Douk and this is what a person values more, everyone can make his own purchasing decision. I bought my combo for less than $250, the DAC has a headphone amp, and the amp has a high-pass filter. These two features, combined with the (more importantly) $150 difference make my choice a very easy one. The last thing I miss is 10 extra db SINAD. But absolutely, to each their own.
The Douk A5 does not lack PFFB. As for the rest, well, I would be more than happy if they send a unit to be measured here on the forum. It will surely have a more striking impact regarding the concepts of "value" and what a good/bad deal is.It's not merely about SINAD. It's about lack of PFFB (and therefore load dependency) and power figures listed without any noted impedance or distortion, or whether the figure is continuous or transitory. I'm quite certain the power figures in an ASR review would not resemble what they are listing.
You’re citing what, for example? I suppose Aiyima a80? Although that amp actually costs twice as much as Douk A5 and still doesn’t quite get it (PFFB) right.Interesting, I did miss the mention of PFFB for the Douk. I haven't yet seen a box that cheap implement PFFB well (I believe at least one or two have been measured where the PFFB implementation failed to eliminate the load dependency). Would definitely be interesting to see proper measurements.
In any case, until those measurements happen I feel confident in assuming that the Douk is not in the same performance class as the Vibelink (which is basically a slightly improved version of the Amp Pro's amp section it seems). It's certainly seems a perfectly cromulent budget amp, though.
Yes the A80 is one example. I want to say I remember seeing at least one or two more, but I'd have to search through the amp reviews to actually find them as I don't recall the amps off-hand. Or my memory could be faulty.You’re citing what, for example? I suppose Aiyima a80? Although that amp actually costs twice as much as Douk A5 and still doesn’t quite get it (PFFB) right.
That's correct.Does this mean that you somehow measured the performance of the DAC+Amp? Is the DAC contribution to the measurements negligible? It's not a critic but rather pure curiosity.
It all depends on what job you want to do. I don’t see any trickery here.DAC included is great. Although Wiim try to trick people to buy Wiim ultra, Wiim mini will do the job.
WiiM-pSome suggestions:
WiiM Amp...Just Amp
WiiM Amp Loud
WiiM Not WiiM
WiiM Amp Minus
WiiM MiiW (pronounced mew like some cats do)
WiiM Power DAC
WiiM Macro
WiiM Artlu (it's ultra...but backwards)
-Ed
Some measurements here. PFFB seems good. Weirdly high distortion though, increasing steadily with more power, hitting 1% THD at 40W for the 32V PS.Interesting, I did miss the mention of PFFB for the Douk. I haven't yet seen a box that cheap implement PFFB well (I believe at least one or two have been measured where the PFFB implementation failed to eliminate the load dependency). Would definitely be interesting to see proper measurements.
"Trick" is unnecessarily critical. It's a matching amp to the Ultra. If YOU want to use a Mini, knock yourself out.DAC included is great. Although Wiim try to trick people to buy Wiim ultra, Wiim mini will do the job.
The Dolby thing using their multi-room tech to add wireless surrounds is in beta already. See https://faq.wiimhome.com/en/support...ing-up-a-wiim-dolby-5-1-surround-sound-system"Trick" is unnecessarily critical. It's a matching amp to the Ultra. If YOU want to use a Mini, knock yourself out.
Consider also that Ultra supports DD5.1, so this amp will power FL/FR with virtual center with Ultra. Add 2 wireless Wiim speakers for back/surround and a powered sub you've got a tidy Dolby 5.1 surround system and solid 2.1 stereo system, with better specs than almost any AVR...and very competitively priced.
I think it's a unique, high quality/value solution. Again, kudos Wiim.
