WiiM Vibelink Amp Review
Rate this amplifier:
    Votes: 9 2.6%
    Votes: 25 7.1%
    Votes: 180 51.4%
    Votes: 136 38.9%
Amp Ultra price.
Yes buying AU just for use as a dumb power amp would be a choice.
About the same price as 2x 3e A7 Mono maybe less with PSU that gets every last bit of the extra power.
Certainly gives more future flexibility.
IOM Ultra and Brick both feature the new NCx252MP now.
With over 500 € they are a good bit more expensive than a Vibelink though. Amp Ultra price.
The WiiM Amp Ultra is now up to 640 € (regular price), but still a bargain in my book.
I find it weird how some people find the Vibelink Amp weird, though, just because it has a volume knob. ;) The one thing that is a bit strange (the Vibelink Amp is lacking PBTL, while the all-in-one Amp Ultra has it) is hardly ever mentioned. And obviously, this is not even important for all but the most demanding speakers.
Have there been cases where the Vibelink can't handle difficult speakers?
It has to power C6Bs here, they are fairly difficult, but no real challenge I guess.
I would call the C6Bs a typical 4 Ω speaker, not exactly demanding. EPDR is commonly agreed on to be a meaningless figure for Xlass-D amps. Plus it comes with an integrated high pass filter so there's hardly any power drawn below their resonant frequency. In short, I absolutely agree that the WiiM Vibelink Amp can drive them with ease.
It's the really low loads below 3 Ω where PBTL can show some advantages, but these speakers are rare, indeed. Talking about the Amp Ultra, it cannot even make the most out of its two TPA3255 chips because bit is limited by its PSU into extremely low loads.
The biggest advantage might be better heat transfer from two chips than just from one chip. OTOH, the case of the Vibelink Amp isn't as stuffed as the Amp Ultra's.
Do you think PFFB is also as (un)important as multiple TPA chips / PBTL ?
For all but edge case difficult speakers?
IMO the Vibelink is clearly the older design from WiiM. The Amp Ultra is their latest release and they of course integrated the "updates" in the form of PBTL and ESS 9039 there from the start.
People buying speakers with a challenging impedance curve below 4 ohms and low sensitivity are probably aware of this. Or should be, if they want serious SPL and intend to use a TPA amp vs a Hypex or Purifi (or something completely different).
No, personally I think that PFFB is more important and all WiiM amplifiers except for the original WiiM AMP have it. PFFB also reduces distortion in general. Not just distortion produced by the chip, but also by the output filter. That's a good good thing.
Yes, the Vibelink AMP is older, but marginally older. The DAC chip is the same in the Vibelink AMP and the Amp Ultra.
The original Amazon description of the Vibelink Amp (before it became available) explicitly mentioned dual TPA3255 chips. This error has been corrected swiftly when I asked for it. I assume (and this is just a wild guess) that the Vibelink Amp might have been planned with PBTL originally, but they didn't manage the additional pop and click noises often seen with PBTL, so they went with the "easier" design. I could be totally wrong.
I received a Vibelink amp today, purchased online in the UK from one of the major online AV retailers. The volume knob has what I would consider a lot of play/wobble off-axis, to the point you can hear some internal plastic binding at points in the rotation. I have read a lot of reviews of the Vibelink and have not seen that raised as a criticism. Would appreciate it if any owners here can chime in and tell me if this is normal, and if my expectations are too high from a 'budget' amp these days.
I've initiated a return as it does not feel right to me and I'm reluctant to remove the plastic wrap and set up the unit to test as it may affect my return. I'm a little concerned it's taken a whack during shipping, and while Wiim do the nice 'Apple' boxes, there is not a great deal of protection when these are being shipped without an additional carton. The packaging does not show much mishandling, but the dinged corners tell me it's not had a journey entirely free of incident.
A shame as the sale price was good and having read a lot of reviews (mostly here) of affordable class D amps over the last few years the Vibelink seems to fit my needs best (I also have the Ultra Streamer which I have been happy with). If the volume knob on my unit is an exception I will probably have to make a trip to a larger town where I can buy in store. Slightly regretting I didn't do this in the first place but would still have been handed a sealed box which I'd not have opened to check in store anyway.
my Vibelink's volume knob doesn't have any play.
have you seen this ? people choose to ignore its "built in" faults
The WiiM Vibelink Amp uses a fully analog potentiometer which shout have a good heft to its rotational movement and virtually no off-axis play at all. If it does, it's most likely broken.
Apart from one man on his crusade most users and reviewers (including Amir) agree that it's a very fine piece of kit with useful features. Unless it's broken.
Thanks for the responses, greatly appreciated - and confirm my doubts. I’m aware it’s an analog potentiometer, and rotationally the unit I received is smooth (minus what appear to be the case and knob rubbing in spots), it’s just that the knob itself seems to have a lot of play independent of the pot itself. Not floppy loose, but moves to the touch, and it immediately gave me the ‘something is not right’ feeling - ie if you hold the knob top and bottom, you can rock it without much force over a milimetre, maybe two off axis. If it was 2nd hand I’d open it up and attempt to improve it but not touching a brand new unit.
I know the thing has some drawbacks, kind of expected as the Ultra Streamer has its own foibles. But one of the main reasons I had decided upon the Vibelink is that it has the separate analogue path; I play computer games on the TV and that reduces/removes the audio latency vs. other Wiim models. I can then feed the Ultra Streamer in through the digital side, Vibelink having much better connectivity than most of the other highly-rated budget Class D amps.
I’ve come to accept that within my budget nothing is going to be as ‘perfect’ as my aged Onkyo A-911 has been, but that has developed an intermittent channel fault (suspected relay) and probably is well due for a total recap and service - probably costing more than it’s really worth.
Thanks again for the responses. I’ll return this unit and try to find a ‘local’ retailer that has stock in store (and hopefully a unit on display so I can be doubly reassured it’s not a degree of production tolerance).
I bought my Vibelink for the same reason that it has analog input that uses what I call a pure direct mode with no ADC conversion. My volume control is precise and tight - as it should be. The Vibelink may be considered a budget piece of kit in price, but certainly not in performance. Mine stays on all day long and is in use at my shop desk area for Near Field Listening. It's driving a pair a KEF Q1 Meta speakers. Hope you're successful in getting a replacement from the dealer.
That's the best scenario you can have. Feed from Ultra via digital and leverage the ESS9039 directly by the amp. And pure analogue for the other purpose.
Yes, I’m just feeling a bit ‘once bitten…’ about the volume knob issue with the first unit, and will now wait until I can find a store with a display unit I can test. Since the volume pot is not motorised I’ll spend a lot of time using that physical control. Curious why the did not use a digital encoder there.
Having to use the sub out of the Ultra streamer gave me pause for thought originally as with my setup I’d need to use the volume control on the Vibelink and everything gets a bit convoluted, but I was willing to accept that. I assume the two amplifier paths on the Vibelink is why Wiim did not include sub out on it. I’d have purchased the amp ultra if that had ‘direct’ mode for its analog input and moved on my Ultra Streamer.
Considering DIYing a full recap and service on my old Onkyo, but I know I’ll never actually get around to it, and the fault will end up being a different component I do not have the skills or equipment to diagnose or fix. The thing is about 25 years old now so not unexpected.
Maybe you can find a fixed knob position on the Vibelink. That will then also scale with the sub as measured and set.
To maximize quality it is preferrable to use the dynamic range of the Ultra. So something like 80% total volume from it and the Vibelink set to what you feel 80% of the max. volume should be.
Or, have 12 o'clock for the Ultra and free range for analogue in. Not 100% precise but OK with the integration from the Ultra.
Delay is a sensitive issue. I'm not sure there aren't more ways to mitigate it with the Ultra analog in. Or optical in > optical out. Maybe others can chime in there.
Personally I see units like Vibelink as power amps, lots have level control these days I just use for gain matching mostly "set and forget".
I may end up with many, 1-2ch each.
The Ultra makes the most flexible front end input "hub", even if its DSP, bass management etc go unused - concurrent outputs are a plus.
An Amp Ultra is much more limiting, unless you buy it just as a downstream power amp because it has higher output than Vibelink and all the preamp features make it easy to repurpose later, but IMO too pricey for that.
Nice thing about "separate power amps" these days, so many great value units with great specs no need to stick to Wiim for those components
modular upgrades / replacement, swapping speakers down the road...
Amp Ultra is sometimes on sale / b-stock here for 499 €. For those seeking all-in-one it's perfect.
I think the amp is better as it features 2 chips. The newer DAC is also included as in the Vibelink.
The Vibelink really shines when you use the source selector, the ESS9039 with digital in and pure analogue in. It's also often available at pretty low prices, below the Ultra. The combo is slightly cheaper than the Amp Ultra at regular price. And way more versatile while keeping the nice design.
As far as I can find, all the Wiim devices bar the Vibelink have an audio latency of 40ms+, far from ideal for gaming which is a serious consideration for my living room 'do it all' setup.
I currently have the Ultra outputting at 100% and use the volume on the *integrated amplifier*. The Onkyo amp (RIP) had direct mode which I could switch to when listening to music through the Ultra, allowing me to use the Ultra's PEQ. Toslink from TV for movies let's me use the sub connected to the Ultra. For gaming I have analog into the amp from the TV, so I don't get the sub, but I'm not bothered about that. I like the Ultra Streamer a lot.
I'd considered the 3e A5/A7 and Topping Mini300, but the 3e stuff is not readily available in the UK and I'd rather avoid another power brick as my setup already has *a lot* tucked away under it. Vibelink is very 'neat' in that respect. I waited until the periodic sales for the Vibelink and price then was OK (I'm not wealthy). Reluctance to order it again online will likely mean I'll have to pay another £50 if I can find a dealer nearby which is a bit annoying. But I fear I'm derailing the thread now.
