Especially optical isolates it away when it is indeed a ground loop.PC works absolutely fine - it just has horrendous noise coming out of the speakers connected to the Vibelink whenever the GPU is under load
when I say bad noise I mean even at medium volume you can hear the digital noise /interference through the Speakers connected to the Vibelink and the intereference noise is as loud with the AVR at minimum volume/muted as it is at higher volumes
I had used active JBLs as Front Left Right a while back with no issues, and I have a Genelec active speaker as a center (8030C) - with no issues
pretty certain it's a ground loop and pretty certain its going to be very difficult to get rid of so the Vibelink might have to be returned
switching inputs on the Vibelink to coaxial or optical seems to isolate the ground loop which is a bit odd (nothing connected to those inputs though)
But I guess that's no option with the Denon, the pre-out is analog only?
Lots of stuff on the PC can produce distortion. But if the interference is not there when you use the Denon amps, it's not that.
