I also experienced the random 'no sound' bug when I had the vibelink connected via coax to the ultra, but since I swapped to optical a month ago its worked perfectly.i mentioned several times specifically the issues me (and others) experienced with the Vibelink, you can search this thread (i already written them at least twice here)
the DAC issue happens when the Vibelink turns on but there's no sound. switching inputs workarounds this.
bluetooth is a useless feature that sometimes doesn't work - the Vibelink appears in the app as disconnected or doesn't appear at all. could be phone issue, BT stack - whatever. i'm not the only one who experienced this.
WiiM Vibelink Amp Review
You could also add a small, good DAC to the vibelink. And hook the Pi usb up to that (check compatibility first). Applies to any poweramp. The vibelink also does analogue amp just like them. But one of the outstanding things of the vibelink is it's DAC and 3 inputs. I also recommend using...www.audiosciencereview.com
