fritobugger
Very nice amp section but wtf were they thinking regarding inputs? One line input. No USB DAC and no bluetooth. Really limits the usefulness of the unit.
Ultra has a sub out, while the Mini and pro don't have itThanks for another review, always appreciated.
Seems a decent Amp, I like the neat form factor and layout. Enough power.
What I find strange is that to get better performance you need to use the internal DAC. Good with the WiiM mini, or Pro but less of a good idea with the Pro Plus or Ultra (they have better DACs)
It would work well with a CD transport, but that's an odd combination.
I realise that the performance with analogue input is probably fine, but it's not exciting.
Nice looking Amp though.
not necessarily... the ap being a development around 2010..its toslink probably limited at 96k..Thanks @amirm for this appreciated rewiew, i was quite curious about this iteration of the AMP WiiM line.
Sorry if I bother, maybe I misunderstood but is the Toslink input of this amp actually -not-supporting the 24/192 output of the Ultra?
but like wiim amp,it has been tested with toslink multitone. (It requires an audio output file with a sampling rate of 192k, also for 19k&20k) ,funnynot necessarily... the ap being a development around 2010..its toslink probably limited at 96k..
which was rather the norm (which was then forced by a "pro" use , adat, with more flow)
it seems to me that even if not specified..the amp pro also tested in 96k.. but maybe I'm wrong ;-)but like wiim amp,it has been tested with toslink multitone. (It requires an audio output file with a sampling rate of 192k, also for 19k&20k) ,funny
Doesn't the fact that they've put an Analog volume control in an amplifier that was specifically created to go with the Wiim Ultra (which has a volume control) ring alarm bells for those who lightheartedly recommend driving power amplifiers with DACs?It is aimed exactly at use in combination with the Wiim Ultra (same size) or WiiM Pro. As you would use a poweramp - so with the volume fixed at max level.
But that's why I find it a bit weird to include volume control and a DAC (without USB). Curious to hear/find out if the internal DAC is supposed to be an upgrade compared to the Ultra's internal one.
I don't think we know this. It merely has the same form factor, as does the Wiim Amp and amp pro.that was specifically created to go with the Wiim Ultra
Lots of folks on the owners groups claim the Ultra is hampered by its pre-amp (usually none near claims), and unfortunately that rumour has spread, so I suspect the Vibelink is designed to give Ultra users an option to fix the output and use an analogue volume control in the amp.Doesn't the fact that they've put an Analog volume control in an amplifier that was specifically created to go with the Wiim Ultra (which has a volume control) ring alarm bells for those who lightheartedly recommend driving power amplifiers with DACs?
In reality for me generally this amplifier is a hybrid that I do not understand compared to the WiiM offers, it costs more than the wiim amp and a little less than the amp pro, but without all that package of functions that make wiim amp and amp pro absolute best buys, sub management, digital crossover, peq, streaming....I don't think we know this. It merely has the same form factor, as does the Wiim Amp and amp pro.
Even if they do belong together, does having a second DAC ring alarm bells? Maybe we all need two DACs in case one fails?
RCA input performance of Vibelink Amp is not worth matching with Wiim Ultra, at least the measurements don’t suggest it IMO.
If it is to be used with Wiim Ultra then it has to be optical/coax out on Ultra to optical/coax input on Vibelink amp.
And so, it makes more sense (performance wise) to pair Wiim Mini or Pro with digital out to Vibelink.
PS. This is excluding things like small display or other unique features wrt Ultra.
Some people have a really serious aversion to external power blocks.I feel the Fosi V3 mono amps are a better "deal" and "SINAD performance" winner over the VIbelink for the Ultra as a preamp. The Vibelink is $150 more than the $250 Fosi amps which offer more power.
I do appreciate the matching look and built-in power supply of the VIbelink and I may have bought it instead of the Fosi's had it been out, but I don't see any reason to swap over to the Vibelink currently.
If WiiM had offered a $300 Vibelink without a DAC and volume control (a pure power amp), that would be the perfect match for the Ultra.
Why? It's just there for flexibility or when using a cd player or other source with fixed volume output. I have absolutely 0 issues running the WiiM Ultra as a preamp, straight into my poweramp.Doesn't the fact that they've put an Analog volume control in an amplifier that was specifically created to go with the Wiim Ultra (which has a volume control) ring alarm bells for those who lightheartedly recommend driving power amplifiers with DACs?
Well, at least WiiM just confirmed on their own forum that the previously announced price figures "are incorrect". Would you mind a $300 Vibelink with a DAC and volume control?If WiiM had offered a $300 Vibelink without a DAC and volume control (a pure power amp), that would be the perfect match for the Ultra.
I can understand that. Divorcing the power supply does eliminate any power supply induced noise. Mine is sitting behind my entertainment center out of sight. If I was to buy an amp for my Ultra now, I would probably buy the Vibelink for that matching looks.Some people have a really serious aversion to external power blocks.
-Ed
