I think that was me.He still say 135 watt in 4 ohm somewhere
Vibelink issues / things you should consider before buying:Thanks for all the discussion, guys. I only mentioned the 8 ohm wpc (50) elsewhere, but no matter. I assumed it was close to 100w at 4 ohms. Speakers are KEF Q Concerto Meta.
Mine has never made any audible popsVibelink issues / things you should consider before buying:
1. it makes a slight pop sound in the speakers when turned on/off/standby (common among TPA based amps. amp manufacturers who cares about this issue found a solution for this )
2. goes on sale several times a year on Amazon US (20% off = 240 USD)
3. bluetooth connectivity to the app is not the best - after sometime it stop appearing in the app (unplugging from power solves this)
4. i read on WiiM forums on situations where it turns on and there's no sound in the speakers. I experienced this issue myself, it doesn't happen much though (switching sources when it happens solves this)
5. when it goes into "deep sleep"(after 1 hour) and you don't have a remote cable connected, the only way to turn it back on is using the app / power button on its back
all of the above are from my personal experience, of using the Vibelink for over 5 months
1 Nothing here, a little with my amp proVibelink issues / things you should consider before buying:
You've been here long enough to know this isn't true.Improved bass and a smoother less digital sound when playing loud
That is what i experienceYou've been here long enough to know this isn't true.
No, it wasn't. No more than if you thought you saw a ghost.That is was i experience
Since you can’t really do anything with it via the app it disappearing doesn’t really effect any functionality
I use it with an Ultra that has a trigger output so I’ve never encountered the deep sleep issue in my setup.
If you have speakers that are 6dB more sensitive than you can use an amp with 6dB less powerhow much power do we need when you have lets say 6 db more sensitive speakers than i have (around 91db, mine is 8 ohm minimum is 4 ohm)
Which means an amp with 1/4 the power. Or in the more likely case when you are keeping your existing amp, it is equivalent to having an amp with 4x the power.If you have speakers that are 6dB more sensitive than you can use an amp with 6dB less power
The problem is, my TV is alreday connected to Wiim Ultra via optical input (because HDMI ARC is very noisy with my TV), may be I can use a simple optical splitter however my turntable is still problematic in this case..@ozgur the spdif input might solve your ground loop issue. but, no remote control of the volume. you're probably better off connecting your CDP to the Ultra, and control everything from one place & gain its EQ/Room Correction features
my SMSL PL150 CD player is connected as a transport using its optical output to the HDMI ARC input of the Ultra using s cheap adapter from Sonos - https://www.sonos.com/en/shop/optical-audio-adapter . works perfectly, the app shows it as "device disconnected" but everything else works fine.The problem is, my TV is alreday connected to Wiim Ultra via optical input (because HDMI ARC is very noisy with my TV), may be I can use a simple optical splitter however my turntable is still problematic in this case..
Thats a good advice (the sonos).. Thanks a lot.my SMSL PL150 CD player is connected as a transport using its optical output to the HDMI ARC input of the Ultra using s cheap adapter from Sonos - https://www.sonos.com/en/shop/optical-audio-adapter . works perfectly, the app shows it as "device disconnected" but everything else works fine.
and the turntable - there's the phono input on the Ultra or the analog RCA input if you're using a preamp
