Sure, why shouldn't it?Would this pair well with the Acsilab F6B or C6B? Or do Acsilab speakers require a higher-quality amp? What amplifier could drive the F6B or C6B in a similar price range?
Moderate volumes, though I know that this subjective without a dB meter! Definitely not loud. I might not hear someone call my name from the next room over but I will hear them fine if they come up to talk to me. Room is not large but is bizarrely shaped, so not conducive to a quality listening environment, but it’s what I’ve got. I’m sitting about 7-8 feet from the speakers.Your KEF speakers have a somewhat low sensitivity at 85 dB, so regarding power, the two big questions are: 1) How loudly do you listen? 2) How big is your room?
The two options will be audibly indistinguishable.wiim vibelink + ultra or wiim amp ultra ?
Best sound ?
Lowest noise from the combo ? Amp all the way up adjust using the streamer
Streamer all the way up and adjust with the amp, in,out is digital
Why are you thinking of changing the Naim amp? If you are currently not running out of power, then you are unlikely to hear any difference between it - and any other competent amp - so don't change thinking you are going to get better sound quality.So many good amp options now, I don’t know where to land. Do I get this or do I go for a Purifi or Hypex power amp?
I’m using a WiiM Ultra into an old Naim Nait 5i, powering a pair of KEF Q Concerto Metas. I have a Project TT plugged into the WiiM’s MM stage and an Arcam CD running into the WiiM’s optical in.
The Vibelink would tuck in nicely, but I wonder if I should go for something else with more power? I only want to buy once…
ask yourself if you need another DAC - because that's what you're getting and paying for with the VibelinkSo many good amp options now, I don’t know where to land. Do I get this or do I go for a Purifi or Hypex power amp?
Digital out of a streamer like a wiim ultra = much better sinad than analogask yourself if you need another DAC - because that's what you're getting and paying for with the Vibelink
If the amp doesn't have digital in you have to use analog out of the streamer = 30 db difference in sinadWhat's the point in comparing the Ultra's analog input with it's digital output?
The question risen by @anonyless was if the DAC really needs to sit in a separate box or if the DAC built into the WiiM Vibelink Amp isn't really all that's needed. The output from the streamer is digital in both cases.
You're still comparing apples to oranges. Not all analog inputs are the same, not all digital inputs are the same.If the amp doesn't have digital in you have to use analog out of the streamer = 30 db difference in sinad
IOM amp(s) ?this is just one owner subjective opinion of the Vibelink + Ultra combo - the only thing "unique" about the Vibelink is the way it looks sitting above/under the Ultra.
if I were in the market for class D TPA based power amp, I would wait a couple of months for 3e Audio's new line of amps.
No, that's not what i meant
www.audiosciencereview.com
higher quality amp? absolutely not. Power, maybe, Ascilab is on the inefficient side of speaker (< 85dB) so if you want to play them very loud - as low as they can (100dB+) this might lack the power to push that far. But you'd be damaging your ears very quicklyWould this pair well with the Acsilab F6B or C6B? Or do Acsilab speakers require a higher-quality amp? What amplifier could drive the F6B or C6B in a similar price range?
I would alternatively ask, does it really matter if there's another DAC in the Vibelink? Why the framing as though it's a negative?ask yourself if you need another DAC - because that's what you're getting and paying for with the Vibelink
