when you write "replace", do you mean "upgrade" ?Hello everyone. Currently, my system consists of a Wiim Ultra and a 3E Audio A5. Should I replace the A5 with a WiiM Vibelink?
because it's only an upgrade aesthetically wise IMHO, when you already own an Ultra, as it fits perfectly on top of it and carries the same WiiM design language.
audio wise? i couldn't tell the difference. maybe the A5 carries more "power" , but that's a big maybe. the included DAC in the Vibelink is a nice addition and means no RCAs between the two units when you use toslink out (get a really short toslink cable from AE..totally worth the 2$ ).
Also, see my messages here from 2 weeks ago https://www.audiosciencereview.com/...s/wiim-vibelink-amp-review.61343/post-2357279
to cut short - the Vibelink has a low sounding click in the speakers when you turn it off / goes into standby. some members here say "it's normal" . i think it's really not
just to be clear - i didn't buy the Vibelink as a replacement or an upgrade for the A5 - i just needed another amp, and moved the A5 to a second system
