Petrushka
- Joined
- Jun 29, 2024
- Messages
- 1,918
- Likes
- 2,180
I think you will need an adapter for the mini-toslink. I have an Apple speaker with a dual purpose 1/8 inch connector.Yes.
Yes I got an adapter thanksI think you will need an adapter for the mini-toslink. I have an Apple speaker with a dual purpose 1/8 inch connector.
Not aware of it being any differentDoes the wiim ultra have an upgraded cpu over pro plus
A review posted some post ago says Wiim Ultra got right and legft channel for RoomEQ...minidsp flex is significantly cheaper and has dirac option if u use dirac with cd quality not hires. i have flex and wiim pro. tried both room corrections but use dirac mainly for configurability as you can set bass and treble ends of fr.
one issue the wiim room correction does not do left and right seperatly now but i would not be suprised if they did in a future firmware upgrade.
Also wiim uses mobile mic not calibrated mic so it would not be able to be accurate but i also would not be suprised if this is addressed later.
It’s currently got left and right channel PEQ and this week they’re launching a beta programme for L/R auto room correction. Related but separate features.A review posted some post ago says Wiim Ultra got right and legft channel for RoomEQ...
I have something similar. I have the Ultra USB out to an external DAC and Amp and I also have a Headphone amp on the line out.Just a quick info:
yesterday my WiiM ultra arrived and I integrated it into my setup, replacing a SONOS port.
Due to WiiM ultra lacking Airplay I added a WiiM mini for this.
My setup now looks like this:
Streaming Device: WiiM ultra + WiiM mini for Airplay, The mini is connected using optical interface to the ultra and is using the USB port from the ultra for power supply.
Volume Control and connection to the speakers: RME ADI-2 DAC fs connected via optical interface with the WiiM ultra
Speakers: Neumann KH750 + 2xKH310 connected to the RME.
My music is on my Synology NAS (approx, 40k files) different quality, from low end MP3 up to hires and flac files.
Setup of the WiiM ultra was a piece of cake. All works fine and I am happy to have the SONOS stuff kicked out (not because of the hardware, but because of the curently bad software).
Ok, I am using the DAC of the RME instead of the one in the WiiM, but the RME specs are good enough for meand the RME has a better adaptive loudness function IMHO. Last but not least, it has XLR output, so I do not need to convert RCA unsymmetrical to XLR symmetrical.
I planned to go for the Eversolo DMP A8, but currently I see no reason for that step. Price wise my setup is quite attractive I guess.
For Airplay and Plex I have a Raspi 4 with Ropieee and an Allo hat which feeds optical to the Ultra.
My issue has been the sub. If I listen to the headphones with line out, the sub is still active. So I moved the sub to the amp (My Fosi amp has a sub out port) and now
when I do room correction, it doesn't seem to correct the sub correctly.
I'm still fiddlin' with the sub as I'm not sure everything is working correctly in the Ultra software with an external DAC or maybe it's me.
Easy to assess with a basic multimeterI'm probably more disappointed that I don't think the sub scales volume properly with the stereo signal.
You mean by ear?I'm probably more disappointed that I don't think the sub scales volume properly with the stereo signal. I have to increase volume on the sub as I increase. It's fine for most listening, assuming few dynamic swings.
I love the ultra but sub management is meaningfully incomplete. Hopefully this is addressed with software.
Yeah it's by ear. The sub volume is changing, but not enough.You mean by ear?
That's FR,the most important metric in audio,that should be the first thing done right.
Are you sure about it?Maybe something about the settings?
That's x-over job.Is it? I'm not sure how. Happy to try.
Given that there will be different amps and speakers being connected, how does the ultra manage the relative volume anyway?
I can't say I notice same effect in my system, there's no perceivable change in system FR when I alter the system volume using Ultra.I'm probably more disappointed that I don't think the sub scales volume properly with the stereo signal. I have to increase volume on the sub as I increase. It's fine for most listening, assuming few dynamic swings.
And there is how you must configure the x-over properly by increasing of decreasing the gain of each of the two ways.Wouldn't a high power high sensitivity system create more dB per volt? How would the ultra know and compensate for that?
I'm probably asking a dumb question.
Set the Crossover frequency to 60Hz in the App, then disconnect the speaker amp and subwoofer from the Ultra and play a 60Hz sine tone on loop (file attached below).Is it? I'm not sure how. Happy to try.
Volume | Main Out [Vrms] | Sub out [Vrms] | Volume difference [20*log10(Main out/Sub out)] [dB] |
100 | 2.03 | 1.01 | 6.03 |
73 | 1.37 | 0.68 | 6.03 |
28 | 0.23 | 0.11 | 6.03 |
You set the volume offset once in the App to account for the difference in sensitivity between Sub and Mains, and then the Ultra just preserves that offset no matter how loud or quiet you listen.Given that there will be different amps and speakers being connected, how does the ultra manage the relative volume anyway?
