Dr. Noooooo
- Joined
- Feb 19, 2024
- Messages
- 16
- Likes
- 21
Well, lowest bass was around 10Hz so practically meaningless, but also from around 7kHz upwards When placed in 90 degrees angle, which some recommend for better treble measurements, the 3db up to 4dB variation starts much higher. The main point was that when the calibration mic was used with the RC the results were completely different from REW. Might have something to do with the mic placement (I make my measurements next to ear in stereo in REW) but I personally would rather not use this kind of setup for equalisation measurements unless there would be significant variations in the frequency response needed to be balanced.Your UMIK-1calibration file certainly doesn't exhibit a 3 dB variation in the frequency range between 40 Hz an 4 kHz. This happens to be the default range for correction in the WiiM Home App, but you can further limit that range.
Not being able to apply the cal file is not ideal, but it's not the biggest concern with the current procedure. Using REW provides much more flexibility and power but requires a lot more knowledge.
There’s an excellent tutorial by Julian Krause in YouTube:I'm not technical and would have a long learning curve for something like REW. I have my Ultra in a 12' x 15' room where my reclining listening position adjoins a corner on the opposite wall. What sounds good elsewhere has a very boomy bass in some frequencies near that corner. Before the WiiM room correction update I was considering stacking a couple GIK Soffit Bass Traps in that corner. Running flat correction up to 400hz sounds much better to me so far. Still need to play more music to see if that does the trick.
Depending on the music, I turn off the RC PEQ for other listening positions. Perhaps with bass traps the room would be more even and I wouldn't need to turn on/off RC.
The default RC frequency range sounded terrible to me. I'd describe it as hollow vocals and mids, and probably more problems if I had bothered to analyze it further.
Took me around an hour to learn all the steps to get good consistent results. Umik-1 in itself costs less that $100 depending where to buy and REW nothing, one of the best investments to improve your listening experience IMO.
