WiiM Ultra Streamer Preamp Review
Rate this streamer/DAC/Preamp:
    Votes: 7 1.3%
    Votes: 47 8.5%
    Votes: 202 36.5%
    Votes: 298 53.8%
Do I need a separate pre-amp in my stereo system if running all my sources through the Wiim Ultra? This has been touched on several times in this thread, but wanted to make sure I am understanding things correctly. My chain is the Wiim Ultra --> Denon AVR --> Linkwitz Orion speaker system (powered by analog crossover and Rotel 1048 8ch amp with 1V input sensitivity). Since I'm not using the Denon AVR for anything but volume control, I'd like to remove it from the chain.
It sounds like I could simply connect the Ultra directly to the analog crossover / Rotel and limit the output to 1V in the settings. Different people have different opinions on the efficacy of using the Ultra's digital volume control in terms of sound quality, but the view on this forum is that the digital volume control is fine. That aside, I do have concerns about one day running into a software bug that causes full volume to be input into my Orions.
So wondering if perhaps something like a Schiit Sys would do the trick or whether a full-on preamp that can buffer the output signal is needed.
Thanks all.
Just use the Wood Ultra as pre. It's designed to be used like that. There's no need for any additional component that is just used for volume control. Should sound better too.
Have Wiim stated whether or not they will allow the usb port to be connected to a computer for signal output.
I know I cannot send signal via usb unless it is a drive of some sort.
I have an rme adi2 dac.
I believe I can record the optical/ coaxial digital signals via usb port.
Has there been any discussion on this feature possibly coming out on the Wiim ultra in the future.
The USB port cannot accept digital audio signal IN; it only does digital audio OUT (to external DACs) or attached storage (flash drive, SSD, etc.).
-Ed
Not sure if this has been answered already...
When using the Wiim Ultra as pre, can I connect a separate DAC via e.g. toslink/spdif and still use the volume control of the Ultra? If so, can I then just set the volume level on the other DAC (assumed it has one) to 100% or use the fixed output of this DAC? Would the x-over function of the Ultra still work in this case and would the digital out only play the high passed signal AND the sub out (analog out!) would play the low passed signal?
I know the Ultra is already fully transparent, but using another DAC with balanced outputs I could use the XLR inputs of my power amp.
Thanks for clarification!
Yes absolutely it will handle this via Toslink or coax. At one point the USB out did not work with subwoofer. That may have been fixed.
I use line out to a Topping A70 pro Amp for an extra XLR out - same concept.
Ah, thanks! So you're also using the volume control on the Wiim and have the Topping set to full volume?
Correct. I don't control volume at all with my downstream amp - only the Wiim for volume which preserves the bass management features. DAC would be the same (assuming it was doing nothing more than the conversion).
Exactly! That would be my use case as well. Thanks for clarification!
Just as a hint - if you don't already have audible noise in your system picked up between DAC and Amp, then using XLR will not bring further benefits, and you can save some money on a DAC and cabling. You can always change this later if (for example) you get active speakers that need long line level wires which may be more susceptible to noise pickup.
Hello. This thread is sooo long…
Can I connect CD player to spdif (I also use Roon) and use USB to my DDC connected via AES to Genelec speakers ( or even directly Wiim spdif output to AES with short cable) - and I can change volume of CD in digital domain?
I use both CD and Roon but was not able to connect player to Genelec - Wiim ultra looks very promising
Have you asked the kind folks at the Wiim owners forum?
Yes you can connect a cd player and use the Wiim as a preamp and the volume control is done in the digital domain (as is the EQ).
Yes you can.
-Ed
Thank you guys :)
Ordered - we'll see.
If it had AES I could sell both: my DAC (simple but great Musical Fidelity) and DDC (Yellowtec). But yes I can still just use simple COAX-AES cable...
I feel it will be exciting purchase
Others mentioned this before; This thing is so versatile, if it didn't have a streamer onboard it's still a great buy.
The possitives ( sub management, room correction, connectivety like hdmi and usb c out, great dac) outweighs the negatives ( rca line in, headphone out) big time, at this pricepoint at least.
Out of curiosity, there’s a deep rabbit hole you can fall into with no formal privacy policy for the WiiM Home app. The privacy policies just refer to the websites and not their products.
Are folks still having audio drop out issues with Wiim ultra when using HDMI arc?
I've never had one. From an early adopter.
