WiiM Ultra Streamer Preamp Review
Rate this streamer/DAC/Preamp:
    Votes: 7 1.2%
    Votes: 47 8.2%
    Votes: 208 36.1%
    Votes: 314 54.5%
I can’t swap with the A8 easily due to the A8’s location- it’s deeply embedded in a cabinet that’s not easily accessible…
I sent it back to Amazon and ordered another one .
If the new one behaves the same , I’ll try using the ground pin on the unit and flipping the plug.
It’s definitely the HDMI . Happens even when TV is unplugged. So could possibly be from the satellite coax cable , but none of my other setups do it and they’re all using HDMI ARC and all are on same Dish system. Didn’t have this problem when a AVR was in use .
I’ve never had a ground loop this loud before in the last 40 years … makes me suspect the unit. As a matter of fact , I’ve never had a ground loop at all.
Appreciate the sage words everyone….
I’ll update in the next day or two - new one will be here tomorrow.
Bk
Hopefully defected unit.
I switch between speakers and headphones often with my Wiim ultra. Each has it's own PEQ preset and I'm already fatigued switching the PEQ each time I switch the output. This is made worse because I use the Wiim ultra screen to change output at my desktop.
Seems like I have to get EQ from other sources until Wiim puts EQ on the outputs. Right?
Fortunately I was already ordering a minidsp that can handle the speakers. I just need one for headphones.
Space is a concern. I don't want a full DAC /Amp setup like the D50iii/a50. Qudelix 5k or the new Neutron player look suitable. Which would you pick? What other options should I consider?
I went with Qudelix 5k and plugged into the USB. No subwoofer output on USB (yay) and I can set the headphone EQ separately from the Wiim.
Only tangentially related to the Wiim but here it is on the Topping display base. Found a place on Amazon that sold the Large model for the same price as the Small model. Doesn't add anything to the audio quality but it looks nice. :cool:
Fiddled this product at a local store and I thought the unit was somehow broken as the rotary encoder felt as if it was grinding against the plastic front plate as @amirm wrote in his review. Why on earth would they leave it like that in the end product? I mean if you compare it to the Wiim Amp for example, it has a delightful stepped rotary encoder which moves smoothly between the steps. The one on Wiim Ultra feels like scratching finernails agains a chalk board.
I understand this is mainly used via the app (which works wery well in my opinion) but still.. why..? :facepalm:
Reactions: EJ3
I am not in the market for one, but if I were, that scratchiness would instantly eliminate that one from my list.
Erin seemed to suggest his 'scratchiness' went away after quite a few pushes of the selector button and turns of the knob.
It is a little off putting, as I was planning on using the knob and screen when I eventually get one.
Maybe by the time that we are ready to get one, they will have fixed that (and taken a few of the other suggestions that have been made).
I do not have much use for remotes except when I am trying to get the EQ right.
Other than that, I need to keep moving around, so...remotes can be handy but not usually necessary for me (unless they have features that I can only access through the remote, which I think is dumb.)
I received one last week and it does not have this issue. The knob feels fine, so perhaps an isolated issue.
I'm sure it is not isolated, many people have mentioned this, but hopefully it has been fixed!
Nice! But I do think it is not an isolated issue as there's a lot of talk about it online.
Maybe there's something wrong with the tolerances of the vol knob in the first production batch/batches. If that's the case, I think it should somehow be compensated.
Does it do your body fat and pulse as well?
If it hampers functionality I'd agree. I don't think you can expect perfection in a device at this price point with the features it has.
I kind of agree with you - there's a ton of functionality in that little box. And it looks good aswell. However (at least for me) that kind of defect would be a no-go, as how things feel is quite important to me. But you're right, it doesn't affect the functionality per se but I think it does affect the user experience.
Anyway I think it is a good value for money if the knob-feel's not an issue for one.
That's it exactly.
And the scratchyness does get better with time, indeed. Still not as nice as the knob on the WiiM Amp, but back then people were complaining about the play icon rotating along with it, so WiiM tried something new. Not entirely successfully, but nothing serious, really.
Did you know that WiiM are already working on per-output EQ? I don't think there's a lot of competition offering such a feature.
Spit balling. Given that many on this forum have spare DACs and amplifiers, connect a cheap DAC to the USB output, wire the signal wires from each channel to a mono to stereo passive adapter and experiment with Hafler surround sound. Good enough for the living room environments where the Wiim is most likely to be used?
P.S. Not responsible for any damage to your components. Seriously, doing this with electronics with outputs that do not share a common ground can burn out your equipment.
This idea doesn't come from the Right member.
:P
Hi all,
I got my new Wiim Ultra from Amazon, yesterday.
It replaces my recent stacks in my living room
a) WIIM Pro => Topping DX3pro+ => AUDIOPHONICS HPA-S400ET => DIY speaker 7"+7"+1"
b) Amazon TV (HDMI ARC) => SMSL A50pro => DIY speaker 7"+1"
with a single stack
c) Amazon TV => WIIM ULTRA => AUDIOPHONICS HPA-S400ET => DIY speaker 7"+7"+1"
All the music comes from a DLNA server on my DIY NAS and from Radio Paradise :cool:
Looks very tidy and a lot of cables also disapear.
The installation tooks 15min (including 8min for WIIM update)
The Ultra and the Amp are connected with a trigger cable.
Wow, everything works fine:
Auto-Sensing on source change works perfect.
Volume control by Wiim Remote, TV-Remote, IPad buttons, Wiim buttons and Apps. Amazing.
Room correction with Ipad, yep.
The sound is really great ( but I think this comes also from my positve brain bias (FUN))
I like this new HIFI gear very much. Modern hardware and software driven features as it best.
Some years ago, I used the Yamaha MusicCast eco-system. I was happy with it then. But, it had only poor
developments in software and also some version breaks. And very big and heavy devices.
No forums or customer contact, poor.
So, now I'm very happy and I have to find new jobs for the remaining devices :)
Have a nice day, Josef
Hi all,
:cool:
The sound is really great ( but I think this comes also from my positive brain bias (FUN))
I think that all of these are important but the MOST important is POSITIVE BRAIN BIAS.
When I was in Singapore & Thailand (with the same Thai girlfriend), sometimes she would ask me the rhetorical question:
Are we having fun?
If the answer from me was "No",
she would ask "Then why are we doing this?"
