Wiim ultra for senheiser Hd660s2
Ivefan
Italia
Good morning, I have a Wiim Ultra and I'm about to buy the Senheiser HD660S2. Do you think I should also buy a headphone amplifier like the Fiio K13 to make the HD660S2 work best? I already have some Audiotechnica M50X that I use with the Wiim but I wanted to improve the sound quality.
Good evening! Welcome to ASR!
If you're not using heavy EQ on the bass (that would warrant a large negative digital pre-amp), the Ultra's headphone out should be more than fine in regards to volume. What may hinder it is the output impedance, which is not near zero: if anything, it will boost the lows a little bit.
Even an output R of 50ohm (which is close to that of the WiiM) is no problem for the HD660S2 .
0ohm, 10ohm, 32ohm, 120ohm
Okay thanks, I thought the ultra had problems driving the hd660s2
