Yea i m trying to not get bambloozed!Beware spending big money for nothing, other than the fancy branding....
Have fun with that sizeable budget. Lots of nice choices possible.Yea i m trying to not get bambloozed!
I live in a country where i cant try audio gear, can only order online.
I m looking at the he1000 stealth, any thoughts abt that one?
I listen to fast bpm songs (hi tek for example) and like bass.
I have a 2000e budget for the HP i can stretch toe 2500e if worth it.
Topping DX5II also has built-in EQ but apparently some defective units there too.Thanks for the replies folks.
For an E3 would you say the topping a70 is a good match? From the a70 thread it seems some units are defective?
Integrated EQ for the amp? Could the EQ of the wiim ultra work for the e3?
Any model to recommend with an EQ? I'm all ears.
Thanks!
What I read about problems with Topping keeps me from buying from them. If it were a little heightened hardware defect rate and proper service handling, I wouldn't consider it an issue. But when I read along the release of the DX1 II it tells me, this is bananaware (grows while already at the customer). Not something I'd do with audio electronics. But in reality, when looking at established and somewhat bug-free models, I wouldn't expect problems. Topping is one of the big brands. If they produce(d) problems you will read about it a lot on the forums. That can give a false overall impression. It's not that every third box from them has a problem or so.For an E3 would you say the topping a70 is a good match? From the a70 thread it seems some units are defective?
