As RoomFit is merely an automatic Parametric EQ generator, and after calibration you get all the calculated EQ parameters as an editable preset, measuring the difference using the Klippel is really unnecessary.
You can just look at the EQ parameters or the EQ graph and that's 1:1 the difference.
The screenshot below is from a manually created preset, but RoomFit presets are identical in the App:
The PEQ generator is frequently being improved via updates to the WiiM Home App.
It is also configurable in its behavior, and of course the results fully depend on both the room response measurement and on the RoomFit settings.
That makes determining the "efficiency" both complicated and not very useful, as the next software update could invalidate all findings.
